Air Conditioner: Buy, Install & Repair
tdi-seppl
Post23-02-2003, 4:00    Subject: Air Conditioner: Buy, Install & Repair Quote
I'm having a problem with my air conditioner; it's only blowing cold air.
What could be the reason for this? Audi A6, model year 1996.
Best regards, Josef.
Translated on 27-09-2026, 4:08.
renwal
Post23-02-2003, 14:14    Subject: Air Conditioner: Buy, Install & Repair Quote
Thermostat failure, water pump issue, or heat exchanger problem.
'I experienced the same issue with my Skoda Octavia 1.9 TDI. Initially, the engine fan would always start immediately, but after a while, only cold air would come out of the air conditioning, which was terrible when the outside temperature was -10 degrees Celsius. In my case, the water pump was faulty. Check if the passenger footwell is damp; if so, it's likely coming from the heat exchanger.'
renwal
Translated on 27-09-2026, 4:09.
Marco
Post23-02-2003, 18:36    Subject: Air Conditioner: Buy, Install & Repair Quote
Check if the engine still has enough coolant.
Translated on 27-09-2026, 4:10.
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air conditioner smells bad General Tips
No new posts Function and components of an air conditioning system Technical Articles
No new posts Air conditioner advice Transmission, Chassis, Body & Interior
No new posts Air conditioner leaking?? Transmission, Chassis, Body & Interior
No new posts AC Actuator Motors: Buy Online Now! On-Board Diagnostics (OBD)
No new posts AC Smells Bad: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
