Problem bei AFN, kein ladedruck (08-01-2008, 18:02) | Posts 16+
Go to page: Previous  1, 2
Post12-01-2008, 11:36    Subject: Quote
Toshi wrote:
Today, I'm going to try to pressure test the system to see if there might be a leak in a hose or other component.
Translated on 18-07-2026, 10:20.
Toshi
Post14-01-2008, 15:33    Subject: Quote
Okay, please provide the text you would like me to translate from German to English. I will only provide the translation.
Okay, so today I went to Seat and picked up a replacement hose for the charge air duct because the old one had a crack.
Okay, here's the translation:
"Just took it for a test drive, wow, this thing has some serious power!"
However, the joy was short-lived. The longer you drive, the more power seems to be lost. I then did another test drive; initially, it pulled normally, but then there was a lack of power in the higher RPM range, and very quickly it went into limp mode.
Okay, I'm ready. Please provide the German text you want me to translate into English.
Perhaps someone has a suspicion? I haven't found anything yet.
Best regards, Peter.
Translated on 18-07-2026, 10:21.
Back to top Profile PM Email
Post14-01-2008, 19:03    Subject: Quote
Toshi wrote:
However, the joy was short-lived; the longer you drive, the more power seems to be lost.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Maybe someone has a suspicion? I haven't found anything yet
. I suspect it might be a VTG clamp that gets worse with increasing temperature.
Run the VAGCOM actuator diagnosis for the turbocharger pressure control and observe the stroke of the variable turbine geometry (VTG) rod: once after a cold start, and then with a warm engine.
Translated on 18-07-2026, 10:23.
oldewurtel
Post14-01-2008, 20:49    Subject: Quote
Hello Peter,
I suspect it's a VTG clamp that gets worse with increasing temperature.
The stuck VTG (variable turbine geometry) could be a consequence of excessive turbocharger lag caused by the defective intercooler hose.
Often, even a longer and faster drive on the highway can help remove dirt from the turbocharger.
Then, an LDA (Load Detection and Alarm) would be very important to detect a VTG (Ventil-Triebwerk-Gerät) that is stuck in the end position and to prevent it from being operated temporarily with 2 bar of charging pressure icon_eek.gif.
You shouldn't always wait until things reach a crisis point.
Best regards, Kassen.
Translated on 18-07-2026, 10:25.
Toshi
Post22-01-2008, 16:19    Subject: Quote
Here's one more final log entry.
4th gear, full throttle.
After a short drive on the highway, the boost pressure control seems to be working reasonably well. However, occasionally when I'm in fourth gear, if I brake and downshift to third, then quickly accelerate again, it still seems to be sticking slightly.
Hopefully, it will get even better, but so far, everything is working as expected during normal operation.
Thanks again for your help.
Translated on 18-07-2026, 10:26.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with AFN, no boost pressure Upload
No new posts AFN No Boost: Troubleshooting & Solutions Upload
No new posts AJM Turbo: No Boost Pressure? Diesel Engine Technology
