LCode doesn't display all checkboxes
Post12-01-2008, 19:39    Subject: LCode doesn't display all checkboxes Quote
Hi.
Another strange phenomenon on my new laptop with Windows XP.
In LCode, some checkboxes only appear when you hover the mouse over them.
Is this a known issue, and if so, is there a solution?
Thank you.
vagtuning
Post13-01-2008, 0:22    Subject: LCode doesn't display all checkboxes Quote
Which version of LCode are you using?
Post13-01-2008, 21:50    Subject: LCode doesn't display all checkboxes Quote
the 604.0 version included with VAGCOM RKS 704.1.
I haven't experienced the issue of missing boxes with the same software on my old Windows 2000 laptop.
(Dell Latitude D600 or D800, and Dell Precision M4300)
Post14-01-2008, 11:56    Subject: LCode doesn't display all checkboxes Quote
This will only happen if you use the Tab key to navigate through the fields in section 3.
Were all the boxes drawn initially, or do I have to click on the fields with the mouse? If I click on the fields, the bug no longer occurs.
Here's the translation:
"That's what it looks like."
 File size:  30.93 KB
 Viewed:  2583 times
Post14-01-2008, 13:10    Subject: LCode doesn't display all checkboxes Quote
Hi Martin,
The 7xx Beta includes a new version of the LCode, but I don't have any information about what's different.
Have you tried it to see if it works better that way?
Post14-01-2008, 14:33    Subject: LCode doesn't display all checkboxes Quote
I don't know if that's supposed to be the case.
"However, the new LCode doesn't display anything when it loads its own example (see LCode_Bug2)."
If you load a different XPL yourself, you'll see something. It apparently doesn't discard unused bits (see LCode_Bug3).
 File size:  52.88 KB
 Viewed:  3797 times
 File size:  30.42 KB
 Viewed:  2606 times
Post16-01-2008, 10:38    Subject: LCode doesn't display all checkboxes Quote
The following has emerged:
>> The problem with LCode 604 is known, but it only occurs in rare
>> Cases where we haven't updated the old VC 704 in that regard.
Instead of pressing 'Tab', just click in the fields and everything will be fine.
Post29-01-2008, 12:12    Subject: LCode doesn't display all checkboxes Quote
I've tried connecting an LCOde 7xx to a VC 704.
The data can be transferred from VC to LCode, but not back, because the modified codes do not reach their destination.
I'll just wait for the complete new release.
No new posts Golf 5 Gearbox: Won't Shift Gears While Driving Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2: Dashboard shows only range Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS Mobile: Incorrect Data Display? Fix Now! On-Board Diagnostics (OBD)
No new posts LCode Errors: Troubleshooting and Solutions On-Board Diagnostics (OBD)
No new posts 1Z Measurement Block 13: What Does It Show? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Fuel Injection Timing: Diagnostic Tool Results Diesel Engine Technology
