Polo 71: 75 HP Version
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post15-02-2008, 23:25    Subject: Polo 71: 75 HP Version Quote
Hello, I'm shopping online again.
My old 1.4 TDI had 75 horsepower, the 2005 model had 71! (There are also versions with 80 horsepower.)
"Does anyone know the difference in driving characteristics?"
Did they reduce the power to 71 horsepower in favor of quicker acceleration?
My old (non-VTG) camera came with a 1-minute timer that was barely usable. Has that improved?
It seems that only the A2 model with the 90 horsepower engine comes with VTG (Variable Turbine Geometry).
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 20-09-2026, 0:35.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-02-2008, 18:52    Subject: Polo 71: 75 HP Version Quote
Breaking news: I bought a Polo. Engine code: BNM. It pulls well from 1500 RPM, and it runs for 1 minute.
The Fehlespeiche is free.
Leider kann ich die MWB nicht logen, weil die Bereichsgruppen sich nicht auslesen lassen! ZB: 01 Motorsteuergerät wird nicht erkannt- fehlt mir da was (Labeldatei) in VAG Com? Version 704.1
Note: Unlocks hexc 715-00a8d1-b1f5d-24f1f3 olicil-6198.
Translated on 20-09-2026, 0:36.
vagtuning
Post16-02-2008, 19:11    Subject: Polo 71: 75 HP Version Quote
'In the addendum, a digit is missing.'
Generally speaking, it should work, but I haven't had any experience with it on a BlueMotion Polo.
probs.
Translated on 20-09-2026, 0:37.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-02-2008, 19:37    Subject: Polo 71: 75 HP Version Quote
Thanks. I can rely on you for things like this.
Is this the MSG? Version 09. Part number 6Q1937049D, code 09246, component 00AF BN-SG 1S34.
All areas are shown as not occupied, with the exception of area 02: Voltage 14... Volts, and doors are open/closed. icon_cry.gif
But I think we're moving on to a different topic now! (Maybe we should move this discussion.)
Translated on 20-09-2026, 0:38.
vagtuning
Post16-02-2008, 19:39    Subject: Polo 71: 75 HP Version Quote
No, 09 is the body control module (BCM) icon_smile.gif.
01 is the engine icon_smile.gif.
It might be a part number like 045 906 019 BP or something similar.
Translated on 20-09-2026, 0:39.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post16-02-2008, 19:47    Subject: Polo 71: 75 HP Version Quote
You might find it amusing: logically 09 BN STG - voltage and doors.
Don't come to 01, but I want to see icon_evil.gif.
So, that has nothing to do with the label files, right? icon_redface.gif I have no idea.
What should I do? I've already looked for updates, and VCDS (Vag Com) is up to date.
Translated on 20-09-2026, 0:40.
vagtuning
Post16-02-2008, 19:55    Subject: Polo 71: 75 HP Version Quote
'Even if there are no labels at all, you can still find the main cable (stg) yourself.'
Inside, you will only find the terms listed below the advertisement.
At an existing/non-existent connection between VC and...
They have absolutely nothing to do with the control unit.
Why don't you download the English 711 beta?
http://www.ross-tech.com/vag-com/download/beta/current.html
Although it's English, practice makes perfect icon_smile.gif.
Translated on 20-09-2026, 0:41.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-02-2008, 16:30    Subject: Polo 71: 75 HP Version Quote
vagtuning wrote:
If you're clean, you'll also come.
Finally moved it from the internal drive to the external hard drive, then to the laptop, and now it's also in English. - jess - reddy - closed - ugh.
Does anyone want to see my super air mass? I have too much! LL leak? Hardly have I gotten in, and I already hear the fleas coughing icon_wink.gif, but it's fun, thanks.
PS: I don't want to work with multiple versions icon_cry.gif.
Translated on 20-09-2026, 0:42.
vagtuning
Post17-02-2008, 16:56    Subject: Polo 71: 75 HP Version Quote
Does the 711 work?
Translated on 20-09-2026, 0:43.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-02-2008, 17:36    Subject: Polo 71: 75 HP Version Quote
Yes, see the attached file.
vagtuning
Post17-02-2008, 17:39    Subject: Polo 71: 75 HP Version Quote
I'm sorry, but I can't translate text without the actual text. Please provide the text you want me to translate.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-02-2008, 18:08    Subject: Polo 71: 75 HP Version Quote
but now - sorry - (I had to switch to English)
Translated on 20-09-2026, 0:44.
vagtuning
Post17-02-2008, 18:23    Subject: Polo 71: 75 HP Version Quote
I think the result is perfectly fine.
It's always fascinating how well the LD (likely referring to a specific system or process) is regulated in [context].
The small BMN and also the BMS (BlueMotion) are working icon_wink.gif.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post17-02-2008, 18:29    Subject: Polo 71: 75 HP Version Quote
Yes, that aligns with my own experiences!
The question relates to LMM (likely referring to a mass airflow sensor). If the sensor consistently shows a value that is "too high," is this normal to account for aging, and can the returned exhaust mass value be reduced without requiring a vehicle inspection or modification?
Translated on 20-09-2026, 0:45.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 6R On-Board Diagnostics (OBD)
No new posts VW Polo TDI: Specs, Features, & More Diesel Engine Technology
No new posts Polo 86c, year of manufacture 1992 Gasoline Engine Technology
No new posts Polo TDI: Specs, Problems, & Common Issues Diesel Engine Technology
