Which engine control units are compatible with the Passat 3B 1.9TDI AFN?
romsnet
Post21-02-2008, 19:37    Subject: Which engine control units are compatible with the Passat 3B 1.9TDI AFN? Quote
Hello!
Can someone tell me which engine control units (ECUs) are compatible with a VW Passat 3B AFN 1.9 TDI, 110hp, built in 1997, manual transmission? My has the number 028 906 021 DT. VW people said it only fits the 028 906 021 JD part.
Rudi
Post21-02-2008, 19:43    Subject: Which engine control units are compatible with the Passat 3B 1.9TDI AFN? Quote
For the Passat, these were:
028 906 021 DT
later 028 906 021 GL
now just 028 906 021 JD (at least for VW)
Hi Rudi
romsnet
Post21-02-2008, 20:47    Subject: Which engine control units are compatible with the Passat 3B 1.9TDI AFN? Quote
Thanks, Rudi!
You have spread my search, now I can also search for GL.
Best regards, romsnet
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP - Welche Pumpenköpfe passen ?? Diesel Engine Technology
No new posts _DEFINE0_ Welche Getriebe passen an den AFN im Golf 3?_DE... Diesel Engine Technology
No new posts Vw Passat ruckeln neuer Injektor werte passen nicht Diesel Engine Technology
No new posts Emergency Start 1.9 TDI MBK AVF VW Passat 3BG On-Board Diagnostics (OBD)
