MKB ANU Engine Noises: Documentary (Solution)
Michael II
Post05-03-2003, 12:28    Subject: MKB ANU Engine Noises: Documentary Quote
Engine noises similar to a timing belt on the MKB or ANU engine.
Up to chassis number:
7MY V 024641
Cause:
Noises are generated in the preheating valve (diesel filter element) and transmitted through the fuel return line into the vehicle's interior.
Solution:
To investigate the sound transmission, the steel return line at the filter needs to be shortened. Cut out a section of the pipe measuring 70 mm in length and replace it with a fuel hose.
Fuel hose No. N 103 035 01, length 180 mm.
Spring clip, type no. N 102 922 01 x 3.
Tschüss
Michael II
Translated on 30-07-2026, 8:07.
Ratings - MKB ANU Engine Noises: Documentary
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Noise in Car: A6 4B (1999) Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMW 320d Engine Noises: Listen & Diagnose (MP3) Diesel Engine Technology
No new posts AGR Seat for VW Sharan 7N Diesel Engine Technology
No new posts Faulty Sharan Control Unit - Replacement & Repair On-Board Diagnostics (OBD)
No new posts VW Sharan Diagnostic Connector Diesel Engine Technology
