Start of AEL funding - Early value maximization?
mike100s
Post23-02-2008, 15:32    Subject: Start of AEL funding - Early value maximization? Quote
Hello everyone,
What, in your opinion, is the maximum early start value that I can set for the start of production at the AEL?
Background: Timing belt and water pump belt have been replaced. Adjusted the pump to 0.32mm using a dial gauge.
After a few manual rotations, the measurement was 0.29 mm.
Measured at 1550 RPM with an elevated idle speed of 79. Values should be between 45 and 60.
With this setting, it started up like a brand new car.
We have now adjusted the setting to 59-60. 'It's been starting poorly lately, especially when the engine isn't fully warm.'
Now I'm thinking about adjusting the pump again to achieve an earlier start to the pumping process.
How far can I 'exaggerate' it?
Michael
Translated on 06-07-2026, 18:16.
christians
Post24-02-2008, 1:30    Subject: Start of AEL funding - Early value maximization? Quote
"During my AAT (Automatic Air Suspension) inspection, I couldn't access the control unit, so I didn't have any baseline values and had to rely on a test drive and a multimeter. It's not critical. A workshop, in a hurry, had previously set the pump belt a half division, or the width of a tooth, too early. It wasn't running perfectly, but it was working. I would pay attention to the noise; if it was noticeably louder at partial load, it was probably too much." The NOx levels are probably already exceeding the limits, but no one is measuring them.
Gruß Christian
Translated on 06-07-2026, 18:17.
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AHU Start-up Value: Find out the initial value. Diesel Engine Technology
No new posts 1Z Spritzbeginn im LL/bei TL zu früh On-Board Diagnostics (OBD)
No new posts Oil Pressure Warning Light: Early Deactivation? Diesel Engine Technology
No new posts Car Engine Cuts Out Early: Troubleshooting Tips Diesel Engine Technology
