LLT-Rätsel: Wetterabhängigkeit? | Posts 16+
Go to page: Previous  1, 2
christians
Post28-02-2008, 17:31    Subject: Quote
The inexpensive thermometers should contain an NTC thermistor, which isn't exactly known for its accuracy, but it's perfectly adequate here. You definitely won't notice the cable extension; at typical temperatures, the sensor should have significantly more resistance than a short piece of wire. If in doubt, measure it.
Gruß Christian
Translated on 20-07-2026, 13:59.
No new posts AU Speed: Deciphering Rotation Rates Diesel Engine Technology
No new posts 1.6TDI DPF: Mystery Solved - Zero Ash Mass Diesel Engine Technology
This topic is locked, you cannot edit or reply. Air Filter Mystery: Can It Be Solved? Diesel Engine Technology
No new posts Vibrations Issue: Troubleshooting Near 2000 RPM. Diesel Engine Technology
