Hydraulic lifters ticking VW Passat 3BG AVF
KimR
Post06-03-2008, 9:26    Subject: Hydraulic lifters ticking VW Passat 3BG AVF Quote
Hello everyone!
Around the end of summer in 2007, I encountered the following problem:
The engine hasn't been running for 3-4 hours. Are the valves/lifters rattling?
For 2-4 seconds after the engine starts, you hear it, but then it stops.
The engine has only 170,000 kilometers on it.
Ich hätte das selbe problem mit der vorgänger. Das war ein Passat 1998 AFN. DOnce upon a time, someone said...
'Everyone said the hydraulic lifters needed to be replaced. I did replace them, but the problem was still the same! Then, I ended up selling it.'
But now I'm having the exact same problem with my current Passat.
Some people say it's due to the oil filter housing, others blame the oil pump, and still others point to the cylinder head. What should one believe?
Does anyone here know where the problem is located?
I am grateful for any advice!
Kim R.
Translated on 29-08-2026, 14:47.
Post06-03-2008, 9:55    Subject: Hydraulic lifters ticking VW Passat 3BG AVF Quote
Hydraulic systems can sometimes run out of fluid.
If they stop after 3-4 seconds of running, thus fulfilling their function and maintaining pressure, there is no need for concern.
I wouldn't actually do anything until the rattling stops, or if it gets worse when the engine is hot (which could indicate thin oil).
Translated on 29-08-2026, 14:48.
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts Hydrostössel V6 TDI AKN Diesel Engine Technology
No new posts Hydraulic lifters: How much play can they compensate? Diesel Engine Technology
No new posts Austausch der Hydrostössel, welcher Aufwand? Diesel Engine Technology
No new posts 3C: Chiller return line rattles Diesel Engine Technology
