Passat TDI 2002: Euro 3 Specs & Info
holgmi
Post06-03-2003, 21:55    Subject: Passat TDI 2002: Euro 3 Specs & Info Quote
Hello.
I was offered a Passat, manufactured in May 2002, with a 74 kW PD engine.
The letter only mentions €3.
How can that be?
It was previously a rental car.
Should I stay away from it?
I might be able to get it for a good price...
Holger.
Translated on 26-08-2026, 6:56.
Post07-03-2003, 8:13    Subject: Passat TDI 2002: Euro 3 Emission Standard? Quote
Hello Holger,
How can that be?
"... that's normal! The Passat is only available with the EU3 engine (ATD). The AXR engine is only used in the G4, Touran, and Polo."
See also:
http://www.volkswagen.de/passat/datson/motoren/74kwdies.htm
Okay, the issue with the rental car is a problem in itself. However, given the current warranty conditions (2 years of factory warranty), I don't see it as a major problem.
Translated on 26-08-2026, 6:57.
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2002, Poltergeräusche Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2002 ABS/ESP Fehler On-Board Diagnostics (OBD)
No new posts 2002 Passat 1.9 PD Kaufberatung Diesel Engine Technology
No new posts Grundeinstellung CLIMAtronic Passat 3BG Bj.2002 On-Board Diagnostics (OBD)
No new posts Passat MKB AVB BJ 2002 1,9TDI Kraftstoffanlage entlüften On-Board Diagnostics (OBD)
