Audi A3 8P Blower Motor/Fan
austrogolf
Post15-03-2008, 15:01    Subject: Audi A3 8P Blower Motor/Fan Quote
hello,
In a 2004 Audi A3 8P, both fans continue to run even after the engine is turned off, even after more than twenty minutes, despite the coolant temperature being only around 30 degrees Celsius.
Unfortunately, I don't have the SLP (Service Logbook/Repair Record) for this vehicle (engine code: BKD). Can anyone help me with this, or has anyone experienced a similar issue before?
"Thank you."
PS: I forgot to mention: The error logs are clear, and there are no fan problems in the memory.
Translated on 20-10-2026, 23:50.
vagtuning
Post15-03-2008, 20:29    Subject: Audi A3 8P Blower Motor/Fan Quote
Since the control unit is located inside the fan, and the problems associated with it are well-known,
Okay, let me put it this way... you're going to need new fans soon, or you'll be running into problems.
...to leave a dead battery somewhere...
As a solution, there were two complete sets specifically provided to be installed in that situation.
1K0 998 455 (frame 680x420) or 1K0 998 455 A (frame 680x460).
Consisting of 2 new fans and a modified fan frame...
Costs are around 240 euros per set.
So, if it hasn't been converted yet, then get acquainted with something like this.
Translated on 20-10-2026, 23:52.
austrogolf
Post19-03-2008, 19:45    Subject: Audi A3 8P Blower Motor/Fan Quote
Thank you for the response.
Unfortunately, you were right - it was the main fan, or rather, the control unit.
However, I have another question: when are the fans turned on?
Thank you for the additional responses.
Best regards, Jürgen.
Translated on 20-10-2026, 23:53.
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Fan Not Working: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts Upgrade Fan: Install 450W Fan Transmission, Chassis, Body & Interior
No new posts Coolant fan control unit??? Diesel Engine Technology
No new posts Fan Always Running? Troubleshooting Guide Diesel Engine Technology
