"Hi, can anyone from the TDI tuning community tell me if the engine control units (ECUs) in a 3rd generation Golf TDI (AFN) can be reprogrammed (e.g., from manual to automatic transmission)? VW naturally says no, it's not possible. I'm from Seelze, near Hanover. Is there a specialist here, perhaps with the necessary technical equipment? Where is the ECU located, and can you see a part number on it, or do you only see it when you connect a diagnostic tool?"
Reason: The well-known warm start problem persists, despite a new battery, temperature sensors, and a functioning starter.
"Hello"
thomas
Translated on 26-08-2026, 19:44.
