Error 01039 and 18047: Relationship and Causes
svet
Post01-02-2008, 16:23    Subject: Error 01039 and 18047: Relationship and Causes Quote
I've owned my VW Passat B5, manufactured in 2000, with engine code AHH and 66 kW, for about 7 months.
Reading the error memory previously revealed the following two entries:
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible signal P1639 - 35-10 - - - Intermittent.
and
01039 - Coolant Temperature Sensor (G2) 30-10 - Open or Short to B+ - Intermittent.
However, it has only happened three times that my vehicle went into emergency mode and the accelerator stopped working.
I've read a lot about error code 18047, and I know how difficult it can sometimes be to fix.
About two weeks ago, I replaced the G62 temperature sensor myself, which solved the temperature gauge problem. Now, the question remains whether there is a connection between the two issues.
01039 and 18047.
Could it be that replacing the G62 temperature sensor also resolved the fault code 18047?
Translated on 12-10-2026, 6:38.
svet
Post10-04-2008, 19:08    Subject: Error 01039 and 18047: Relationship and Causes Quote
"Everything comes in its own time... that's how it happened for me."
Since I replaced the G62 temperature sensor on January 19th, my Passat no longer goes into limp mode. It's been almost 3 months, and I believe the error code 18047 can now be considered resolved.
Translated on 12-10-2026, 6:40.
No new posts ABS Error Troubleshooting: Find the Cause Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zusammenhang bei PD zwischen Drehfreudigkeit und SyncWinkel? Diesel Engine Technology
No new posts Error 18047 - Accelerator Pedal Sensor Diesel Engine Technology
No new posts Faulty Door Control Units: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts A6 2.5 TDI: 1000+ Common Problems & Fixes Diesel Engine Technology
