Function of pressure regulating valve or control gear in the AFN
oldewurtel
Post27-04-2008, 20:43    Subject: Function of pressure regulating valve or control gear in the AFN Quote
Hello fellow enthusiasts,
While trying to find the cause of the increased oil consumption in my car (approximately 0.3 to 0.4 liters per 100 km), I've now reached the flat, round container on the valve cover.
The part is called a 'pressure control valve' by Audi. What pressure does it regulate?
Even after an extensive search using the search function icon_wink.gif, the true function remained hidden from me.
How is this supposed to work in order for it to be okay?
The two connections (from the valve cover and from the crankcase) appear to be equivalent.
It seems that the connection to the ATL can apparently be closed off using a membrane (with a valve).
In my modified version, all three connections are linked together. It's possible to blow air through them.
Therefore, the ATL would suck in everything that comes out of the crankcase. That somehow makes sense...
If I strongly draw fluid into the connection for the ATL (hmm, delicious fully synthetic oil...), and then close the other two connections, the membrane valve will seal that port, allowing you to reopen the other connections.
Is this a feature or a bug?
Normally, there is only a very slight vacuum inside this hose, while a larger volume is available on the crankcase side, so it should never be able to close off completely, right?
Of course, you could simply buy the thing from a dealer (but first, perform the 'suction test' at the parts counter and, if necessary, return it icon_rolleyes.gif).
But most likely, this part will cost at least 20 euros again, which is money you don't have to spend if everything were okay.
K. Oldewurtel
Translated on 14-07-2026, 15:46.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts Exhaust gas recirculation: function and problem areas Technical Articles
No new posts Oil Leak at Pressure Regulator Valve - Cylinder Head Vent... Diesel Engine Technology
No new posts Function of the NW-adjuster on the 2l TSI? Gasoline Engine Technology
No new posts Haldex Failure: Tiger Problems & Fixes Transmission, Chassis, Body & Interior
No new posts Function of the VTG control on the VW T5 TDI (AXE) Diesel Engine Technology
