Kolben gerissen am Brabus D3 | Posts 16+
Go to page: Previous  1, 2
efistho
Post23-04-2008, 17:01    Subject: Quote
Meanwhile, the car is 7 years old, and in this case, a new car is being purchased instead of trying to keep the old one running. This is simply uneconomical.
The repair doesn't really make much sense.
Alternatively, a complete exchange unit could be used.
It's a real dilemma.
Translated on 19-08-2026, 1:51.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post23-04-2008, 18:26    Subject: Quote
Hello Rainer, I understand that the proposal may not be scientifically sound and could potentially be quite large.
Assuming I wanted to invest as little as possible, I thought that the lifespan would still be better with the edge extended outwards, rather than if the nozzle continued to spray onto the edge.
"Brabus" sounds like something for racing enthusiasts, expensive, and luxurious... but when I see this, with its extended pistons, I realize I'm in good company icon_twisted.gif.
You should definitely treat yourself to a new piston.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 19-08-2026, 1:52.
efistho
Post24-04-2008, 14:18    Subject: Quote
I think adapting pistons to a power box is a bit like carrying owls to Athens. icon_biggrin.gif The shape of the recesses is also an essential design element of the piston itself. Removing the box and using pistons in series form seems more straightforward. A well-executed performance increase doesn't necessarily have to be achieved through adjusting valve timing. Of course, all within the limits of the system.
I also posted those photos to warn about the dangers of extending injection times in common rail engines.
The engine needs 4 pistons and a new cylinder head. At that point, it would also make sense to recondition and replace the bearings. If you're already working on the chain drive, turbine, and high-pressure pump, you might as well consider investing in a replacement engine.
"efistho" (This appears to be a single word with no apparent meaning in common English vocabulary.)
Translated on 19-08-2026, 1:53.
rodNeX
Post26-04-2008, 0:50    Subject: Quote
Brabus sounds like it's about high performance, expensive, and luxurious things...
Brabus, however, is more of a makeshift operation when it comes to engines; they assemble engines that are essentially doomed to fail prematurely. The abnormally high piston speeds and thin cylinder walls due to boring, etc., all contribute to this.
No wonder the diesel boxes are also considered 'cheap.'
Carlsson, on the other hand, has established itself as an excellent tuner for Mercedes-Benz diesel engines.
Translated on 19-08-2026, 1:55.
efistho
Post28-04-2008, 11:54    Subject: Quote
Without knowing for sure, I would say that the C-Tronic from Carlsson does the same thing.
Translated on 19-08-2026, 1:56.
rodNeX
Post28-04-2008, 12:21    Subject: Quote
However, it has some 'protective features,' such as the extra power only being available when the engine oil is warm, etc.
efistho
Post29-04-2008, 9:16    Subject: Quote
However, increased performance with warmer engine oil does not protect against problems caused by cold engine conditions, and in the aforementioned case, it would not have saved the pistons.
"No offense intended, but I wouldn't write anything negative about a product without knowing its functions."
Best regards to everyone.
P.S.: The Brabus is running again with new pistons and a reworked cylinder head. icon_biggrin.gif
Translated on 19-08-2026, 1:57.
No new posts Windshield Crack: Documentary of a 1-Year Old Car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tuareg Door Lock: Broken Armrest Release Handle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Damage: Piston 4 Cracked - What Now? Diesel Engine Technology
No new posts Broken AAZ Timing Belt: Causes & Repair Diesel Engine Technology
No new posts AI Breakthrough: No Guarantee Transmission, Chassis, Body & Interior
No new posts Timing belt broken: Causes and repair Diesel Engine Technology
