VP44 no longer delivers high pressure
kuestenkuddel
Post04-05-2008, 20:57    Subject: VP44 no longer delivers high pressure Quote
Hey guys.
Bernie's tow truck has broken down icon_sad.gif. It's a MAN F 2000 with a 4-cylinder engine. TDI, 4.6 liter, 186 horsepower, year 2003.
I am sorry, but I am unable to access external websites, including the one you provided. Therefore, I cannot translate the text from the German website into English.
It stalled while idling and now won't start.
Today, we checked the following: We loosened and cleaned all the injector line union nuts at the injectors = the pump is working properly and in sync with cylinders 1, 3, and 4, and cylinder 2.
Then we removed a fuel injector line and installed it in a way that allows us to screw in a test nozzle. We vented the ESL (Electronic Stability Control) system, tightened the test nozzle, and started the engine, but nothing came out.
I don't know anything about the VP44 and I don't know where to look icon_sad.gif.
Buying a new one isn't really my style.
Can any of you give me a tip?
Bosch Part No. 0 470 504 017
Usage No. VR4/4/65M1200R1000
Best regards, Kurt.
christians
Post04-05-2008, 23:33    Subject: VP44 no longer delivers high pressure Quote
"If it suddenly stops working and then refuses to start again, it's usually the control unit. However, you probably won't be able to access it without a VAG-COM compatible diagnostic tool." Bosch service or brand new.
Gruß Christian
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts VE Injection Pump Data: 6-Cylinder Engine Performance (VP44) Technical Data
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Passat 2.0 TDI - High pressure is below specification Dieselschrauber Bar
No new posts Intercooler Bora TDI 110KW ARL - Suppliers Diesel Engine Technology
No new posts ECU A6 only provides signal intermittently. On-Board Diagnostics (OBD)
No new posts AJM Error Codes: 18074 & 16685 Explained Diesel Engine Technology
