MFA malfunction
chrigu
Post20-11-2005, 15:30    Subject: MFA malfunction Quote
Hello Diesel Enthusiasts
Yesterday, the MFA (Golf 4 ARL, built in 01) probably gave up the ghost. icon_cry.gif
The entire display area is now only emitting a faint red light! The alarm still works: (Outdoor temperature etc.)
Has anyone experienced this before??
On Wednesday, the car will be at the dealer for the 60k mile service.
Best regards, Chrigu
blizzard
Post14-05-2008, 0:42    Subject: MFA malfunction Quote
Yes, it's the same for me, but only the red backlight is still working.
otherwise no advertisement oO
what could it be? Has something gotten stuck?
I'm going to try resetting the battery tomorrow to see if that works.
Best regards
G4 TDI PD 74kw AXR
5tkm 1xAGR Ventil (Geräusche)
144Tkm 1xEUH Getriebe + Kupplung
2x POPO Heizung geflickt
155TKM PDE Kabelsatz (ruckeln)
240TKM Wasserpumpe hin
244TKM MFA selbst rep.
305TKM LL Druckschlauch (Nasen weg
320TKM GLÜHKERZEN erneuert
blizzard
Post14-05-2008, 12:30    Subject: MFA malfunction Quote
Now things are going again
Speedometer removed, disassembled, and then reassembled, as nothing was visibly wrong.
make sure the rubber from the display presses the board reasonably well,
more not.
Additionally, the battery was disconnected to achieve a full reset.
And there it is, I've got another ad.
Best regards
G4 TDI PD 74kw AXR
No new posts C4 AEL KĂźhlwassertemp-Anzeige defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 111kW AHY, Standheizung defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A6 4B, Einparkhilfe defekt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM defekt? On-Board Diagnostics (OBD)
No new posts LMM defekt ? On-Board Diagnostics (OBD)
No new posts AVF: What's wrong with it? Upload
No new posts MKB: ARL PDE faulty? Upload
