Pull Test Tip: Ulf's Guide
Varianti
Post23-05-2002, 13:53    Subject: Pull Test Tip: Ulf's Guide Quote
Perhaps everyone already knows this little trick. However, I haven't read anything about it before.
To find the additional horsepower, one should typically increase that number and then observe how it affects the time it takes to reach the measured value.
There's also a simpler way. In EXCEL, there's a function called 'Goal Seek' (Menu: Tools -> Goal Seek). Open it and, in the 'Set cell' row, select the cell containing the seconds. In the 'Set value' row, enter the measured time, for example, 5.5. In the 'By changing cell' row, select the cell containing the performance value. Click 'OK', and it will instantly calculate the performance value corresponding to the measured time.
Translated on 26-09-2026, 8:24.
Post23-05-2002, 15:39    Subject: SEO: Best German to English Translation Services Quote
... I certainly hadn't seen that before.
I've come across the term "goal-oriented search" a few times before, but...
I hadn't given it much thought.
Best regards, Ulf (PC-Doofi).
Translated on 26-09-2026, 8:26.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Console Light Upgrade: Easy DIY Guide Transmission, Chassis, Body & Interior
No new posts Timing Belt Replacement Tips & Intake Manifold Sludge Diesel Engine Technology
No new posts Golf 4 Glove Box Light: Installation Guide Transmission, Chassis, Body & Interior
No new posts Dyno test for a 150hp V6? Diesel Engine Technology
