Transporter 7D Clutch Problems: Documentary (Solution)
Michael II
Post18-03-2003, 12:43    Subject: Transporter 7D Clutch Problems: Documentary Quote
Clutch pedal too low, difficulty shifting gears (the clutch pedal is positioned too low and the disengagement travel is too short, resulting in gear changes that are difficult and accompanied by slight grinding noises).
Up to chassis number 70Y H 003 429.
Cause:
The clutch pedal is positioned too low, which results in the clutch disengagement travel being too short.
Solution:
Loosen the set screws on the actuator cylinder at the bearing bracket, position the actuator cylinder within the elongated holes of the bearing bracket until it reaches the upper stop, and then tighten the set screws to a torque of 20 Nm.
Please note that the connecting cylinder for the clutch pedal should not be in contact with the switch plate. The distance between the clutch pedal and the brake pedal should not exceed 10 mm.
Tschüss
Michael II
Translated on 29-07-2026, 14:20.
Ratings - Transporter 7D Clutch Problems: Documentary
No new posts Transporter 7D: Documentary about Whistling Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Inaccurate Fuel Gauge Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch problems Transmission, Chassis, Body & Interior
No new posts Kupplungsprobleme Diesel Engine Technology
No new posts Coupling issues (intermittent) Diesel Engine Technology
No new posts Kupplungsprobleme bei Golf Cabrio TDI Diesel Engine Technology
