Solved! Finally finished | Posts 16+
Go to page: Previous  1, 2
Post16-03-2003, 17:45    Subject: Solved! Finally finished Quote
98er_alh wrote:
So far, I have only talked about the battery cables, and I have only tried soldering those, and that has worked for me.
Hi Andreas,
I certainly believe that's possible, especially if the crimp connections were already corroded from the beginning, and you managed to create at least a few square millimeters of a near-zero-ohm solder joint between the cable and the terminal.
@Rainer:
Based on Andreas' experience, I will write a note in the error database icon_wink.gif.
Translated on 16-09-2026, 0:02.
Post18-03-2003, 16:49    Subject: And at the end... Quote
Hello.
For those who are interested, here's the preliminary final result of my starter motor campaign:
Disassembled, cleaned, and the planetary gear was well-lubricated (the factory lubrication seemed a bit insufficient and also slightly dried out). Carbon brushes, commutator, etc. are still in excellent visual condition --> nothing was changed.
Reinstalled, cold and warm starts are essentially as before. It might start a little better when warm, but it's not like "Wow, it always starts on the first compression now" icon_sad.gif.
Shortly after delivery, I had already resoldered the crimped connections on all the thick cables between the battery, starter, and engine block, and I had also lubricated the contact points -> so there is no possibility of voltage or power loss at those points.
Therefore, my tractor remains a somewhat hesitant starter when cold.
If it bothers me, I'll eventually install a temperature sensor that tricks the system into thinking the engine is lukewarm when it's actually hot... we'll see what happens.
Translated on 16-09-2026, 0:04.
No new posts Starter Motor Noise: VW Golf 4 & Similar Troubleshooting & Guides
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 2 Speedometer Removal: Guide & Instructions Transmission, Chassis, Body & Interior
No new posts Removing the Climatronic control unit from a Volkswagen G... Transmission, Chassis, Body & Interior
No new posts Removing rear door panels on a Golf IV (5-door) Transmission, Chassis, Body & Interior
No new posts Replacing the starter motor on a Volkswagen Golf III TDI Diesel Engine Technology
