teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
17-06-2008, 13:52 Subject: Bumper Cover with/without Parking Sensor |
T5 rear shell:
Is there a way to close the holes of the PDC (Pressure Distribution Chamber) with the plugs from the old system without PDC, or are they glued/welded in and will they break when removed?
I have one that was boosted with PDC, but the other model wasn't.  Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 27-07-2026, 17:56.
Profile PM Email Garage |
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7817 Karma: +1093 / -0 Location: BAR
17-06-2008, 14:24 Subject: Bumper Cover with/without Parking Sensor |
The ultrasonic sensors are usually generic devices that are mounted in vehicle-specific brackets. I would buy a cheap parking sensor kit and retrofit it myself. This is certainly also a good idea for a T5. Working systems (with 3 or 4 sensors) cost less than 50 EUR.
Usually, the holes are cut out, the consoles are glued on from the back, and the sensors are clipped in. I had a Bosch system (an aftermarket solution) in my Suzuki Ignis that a friend bought from a scrapped car (a Volvo S70). Since it worked and no one wanted it, it ended up in the Suzuki. It fetched 100 EUR when I sold the car.  Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
Translated on 27-07-2026, 17:57.
17-06-2008, 15:04 Subject: Bumper Cover with/without Parking Sensor |
Okay, yes, if the hole diameter is correct, I'll measure it. Gruß, der Teileklaus
Translated on 27-07-2026, 17:58.
22-06-2008, 18:18 Subject: Bumper Cover with/without Parking Sensor |
I discovered that there aren't any lids at all.
My retrofit sensors are slightly smaller, so I need to compensate for a difference of 1.2 mm!
The OE sensor costs over €60 (x4!). Gruß, der Teileklaus
Translated on 27-07-2026, 17:59.
Hutfahrer Schrauber
22-06-2008, 18:24 Subject: Bumper Cover with/without Parking Sensor |
*Cough* Are there perhaps any retrofit sensors available that are larger?
If necessary, measure the openings and initially purchase suitable plastic caps ("blind plugs"). It may not look aesthetically pleasing, but it still leaves the option to retrofit a system from the manufacturer's accessory catalog if one becomes available at a reasonable price in the future. Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
22-06-2008, 19:03 Subject: Bumper Cover with/without Parking Sensor |
"I already have and tried the PDC accessory box, I'm using that. The sensor has a rim that covers more area. A strip of tinplate (aluminum?) placed in between will provide enough clamping force." Gruß, der Teileklaus
Translated on 27-07-2026, 18:00.
