Hello everyone,
I've been a long-time reader of this forum and have often been able to find solutions by searching. Now, I'm facing a problem where I need your help.
Vehicle: VW Golf 4, model year 2000, ALH 90 hp engine, mileage 183,000 km. Chip tuning by B&B to 105 hp at 70,000 km. No issues except for a faulty dual-mass flywheel. Mass airflow sensor (MAF) replaced at 100,000 km.
Problem: Very slow boost build-up, only reaching boost at approximately 2100 RPM. Perceived power loss of about 20% across the entire RPM range (acceleration without any noticeable "holes"). No mechanical noises detected, no audible air leaks, and the error memory is clear.
The log file is located in the upload area.
Thank you in advance.
Best regards from the Westerwald region.
Maurice.
Translated on 05-10-2026, 15:28.
