Engine Oil Leak: Doku LT 28 Troubleshooting (Solution)
Michael II
Post20-03-2003, 12:50    Subject: Engine Oil Leak: Doku LT 28 Troubleshooting Quote
Oil leak at the engine, leak from the blind plug above the oil pressure sensor.
Cause:
In some cases, there may be oil leaks around the blind plug.
Solution:
If a leak is clearly detected at the blind plug (above the oil pressure sensor), this fitting should be tightened to 25 Nm. The affected area must be cleaned.
Tschüss
Michael II
Translated on 31-08-2026, 8:02.
Ratings - Engine Oil Leak: Doku LT 28 Troubleshooting
No new posts Document: "Liegenbleiber" (Stalling), AKN (Acne Keloidali... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel Leaks: AKF Engine Documentation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AKF Motor: Performance Issues & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil leak 3.0 TDI FLs On-Board Diagnostics (OBD)
No new posts Interessante Doku zum 1.9 TDI Motor Diesel Engine Technology
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
