Emergency Lane: 5 Times on 120km Highway
marcel.d
1997 Volkswagen Golf
Post16-07-2008, 20:23    Subject: Emergency Lane: 5 Times on 120km Highway Quote
"Today, I drove approximately 120 km on the highway and experienced the emergency mode function a whopping 5 times. This always happens when driving at full throttle. The LDA (likely referring to a pressure sensor) then reads 0.8 bar and suddenly drops to 0.1 bar, causing the car to enter emergency mode."
The error code read from the vehicle's computer indicated a faulty engine control unit (ECU), with intermittent issues related to the intake manifold pressure regulation.
Der Saugrohrdruck-Fehler ließ sich ohne Proleme löschen, der Fehler STG defekt ging erst nach dem 5. VPlease proceed.
I also removed the motherboard and saw that the intake manifold pressure sensor is additionally glued with silicone. Is this how it's supposed to be, or isn't it normally held in place by the three solder points and the four plastic feet?
Translated on 18-08-2026, 11:06.
marcel.d
Post16-07-2008, 20:28    Subject: Emergency Lane: 5 Times on 120km Highway Quote
The car is a 1997 Volkswagen Golf 3 TDI with an AFN engine. I forgot to mention that.
Translated on 18-08-2026, 11:08.
TDI-Daniel
Karma: +1 / -2   Thank you, like it!
Post16-07-2008, 20:37    Subject: Emergency Lane: 5 Times on 120km Highway Quote
Normally, it's done without silicone.
Solder joints checked?
Best regards, Daniel.
Audi A6 Avant 4B 2,5l TDI AKE
Audi S6 Avant C4 4,2l AEC
Golf 4 AKL Benzinfresser
Back to top Profile PM Email
marcel.d
Post16-07-2008, 21:28    Subject: Emergency Lane: 5 Times on 120km Highway Quote
Here's how my pressure sensor looks inside the control unit.
http://www.golf3forum.de/attachment.php?attachmentid=70113
http://www.golf3forum.de/attachment.php?attachmentid=70114
TDI-Daniel
Post16-07-2008, 21:38    Subject: Emergency Lane: 5 Times on 120km Highway Quote
It seems normal. In my case, it appears to be an exception.
mullemaus
Post16-07-2008, 22:17    Subject: Emergency Lane: 5 Times on 120km Highway Quote
The internal map sensor is secured with (usually white) silicone. icon_wink.gif
Translated on 18-08-2026, 11:09.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine failure on the highway at 190 km/h, only 3000 RPM ... Diesel Engine Technology
No new posts Seat Leon Coolant Leak: 1.9TDi, Autobahn Use Diesel Engine Technology
No new posts LOG AFN-Emergency Mode Upload
No new posts T5 Emergency: 2.5 BPC Mode Activated Diesel Engine Technology
