kossmann Blaumann
2016 Audi Q3 Premium Support
23-07-2008, 9:10 Subject: VCDS TDI Timing: No 1Z Support |
Hello everyone,
Could it be that in the new VCDS version (by Rainer), when selecting "TDI Timing," only the engine variants "AGR, AHF, ALH, ASV" are available? The dropdown menu only shows this one option. I'm missing the older 1Z variants – specifically, the ones for my 1Z.
I have readings of "t Diesel = 149" and "SB = 23" - according to the graph, this is too late (significantly below the lower line). Now I'm not sure if this is due to the wrong engine variant and whether these values are acceptable for the 1Z engine, or if I actually need to make some changes.
Translated on 15-08-2026, 22:33.
Profile PM Email Garage |
23-07-2008, 9:56 Subject: VCDS TDI Timing: No 1Z Support |
Here's the graph from a 704.1.
| Description: |
| File size: |
141.98 KB |
| Viewed: |
2451 times |
Translated on 15-08-2026, 22:34.
Profile PM Garage |
Uwe@Ross-Tech Guest
24-07-2008, 3:25 Subject: VCDS TDI Timing: Troubleshooting & Solutions |
Hello everyone,
Could it be that in the new VCDS version (by Rainer), when selecting 'TDI Timing,' only the engine variants 'AGR, AHF, ALH, ASV' can be chosen? The dropdown menu only has this one option. I'm missing the older 1Z variants - or the ones specifically for my 1Z.
Do you use the current data as of June 26, 2008?
'With that in mind, the selection should actually look like this:'
http://www.Ross-Tech.net/vag-com/screen-shots/TDIGraph_Selection.png
We have reorganized the engine variants to make them more organized overall and to avoid redundant entries.
-Uwe-
Translated on 15-08-2026, 22:35.
kossmann Blaumann
24-07-2008, 8:34 Subject: VCDS TDI Timing: No 1Z Support |
Hello Uwe,
How can I tell which version of the data is installed, and where can I download a corresponding file? Where should I put this file? I downloaded the complete installation from Rainer's shop a few weeks ago.
When I click on the dropdown menu – or the arrow next to it – nothing happens; no engine options appear.
Translated on 15-08-2026, 22:36.
vagtuning Guest
24-07-2008, 12:28 Subject: VCDS TDI Timing: No 1Z Support |
VCDS > ABOUT, and then at the top, below the version number, you'll find the data status.
Translated on 15-08-2026, 22:37.
kossmann Blaumann
24-07-2008, 17:31 Subject: VCDS TDI Timing: No 1Z Support |
I have the version dated 20080612 – if I understand Uwe correctly, it's not the most recent one.
Rainer... did you forget something in your version, or am I missing something?
24-07-2008, 18:02 Subject: VCDS TDI Timing: No 1Z Support |
Hi Tino,
Why not simply download the latest version and check if the problem has been resolved?
Translated on 15-08-2026, 22:38.
Profile PM WWW Garage |
kossmann Blaumann
24-07-2008, 21:25 Subject: VCDS TDI Timing: No 1Z Support |
I just uninstalled, downloaded a fresh copy, and installed it... and at least the data version is now 20080626. Since I'm currently on vacation in Austria, I won't be able to test this until my return trip (on Saturday), and I'll let you know then. It seems like that was the cause of the problem.
Best regards and thank you!
Translated on 15-08-2026, 22:39.
