Error Code 65535: Troubleshooting Guide
maremio
Post24-07-2008, 9:37    Subject: Error Code 65535: Troubleshooting Guide Quote
Good day to everyone,
Several posts have already discussed this error code, but ultimately, they always end up without a solution.
a correct statement and the reason behind it.
I've now taken my steering device to be repaired (www.technikzentrum.net). Hopefully, I'll be able to provide more details in a few days.
Best regards, maremio.
Translated on 16-09-2026, 5:23.
Tribu
Karma: +3 / -2   Thank you, like it!
Post25-07-2008, 21:38    Subject: Error Code 65535: Troubleshooting Guide Quote
hi...
Error code 65... is a software error triggered by voltage spikes.
Irreversible.
The control unit can then only be updated with new software.
When we're talking about the airbag control unit: 6Q........
Then it's probably best not to have it repaired and just buy a used one instead.
You can find the new part number from VW, and if it is indeed the airbag part, I can look up the number for you. The problems no longer occur with this part. I paid 60 euros for one on eBay, and -> It's absolutely great!
Greetings, Tribe.
Translated on 16-09-2026, 5:24.
maremio
Post29-07-2008, 8:00    Subject: Error Code 65535: Troubleshooting Guide Quote
Tribu wrote:
hi...
Irreversible.
You can find the new part number from VW, and if it is indeed the airbag part, I can look up the number for you. The problems will not occur again. I paid 60 euros for one at [website/store name], and -> Absolutely top quality!
Greetings Tribe
Hi, thanks for the reply.
Am I understanding correctly? Is the problem not related to the engine control unit?
But it's the airbag control unit!!!!!!!
The MSG is already being repaired, and it should be finished by Wednesday. Let's see what they write in the inspection report.
Translated on 16-09-2026, 5:26.
No new posts Airbag Error 65535: A3 8L Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Error 65535: A3 8L Fix (up to 8LYA078299) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1351 General Tips
No new posts Error Code 65535: What does GRA Reset mean? Diesel Engine Technology
No new posts Error Code 65535: High Idle After Startup On-Board Diagnostics (OBD)
No new posts Defective Control Unit: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts A3 TDI: Airbag Error 65535 - Troubleshooting On-Board Diagnostics (OBD)
