Timing belt replacement - tools for PD models
bernie123
Post25-07-2008, 22:02    Subject: Timing belt replacement - tools for PD models Quote
Hello forum,
What about the suitability of timing tool kits for replacing the timing chain on PD engines? These kits are offered on online marketplaces starting from around €20, are they good quality or not? Some kits are missing the double-pin key, what dimensions are required for that?
"asks"
bernie
Translated on 08-07-2026, 2:09.
Stefan-TDI
1997 Volkswagen Golf
Post30-07-2008, 22:35    Subject: Timing belt replacement - tools for PD models Quote
I bought this stuff from the VW dealer. The lower part costs around 25€, the pen probably costs 5€, and the two-hole reamer is available from Hazet for about 10€.
When it comes to tools, I prefer to buy something good rather than a cheap imitation.
Translated on 08-07-2026, 2:10.
Post31-07-2008, 7:49    Subject: Timing belt replacement - tools for PD models Quote
And for the pen, you can use the 6mm drill bit that you already have, and then everything will fit.
R00KIE
Post31-07-2008, 10:17    Subject: Timing belt replacement - tools for PD models Quote
Does 'das untere' refer to the KW stop or the locating pin for the belt tensioner?
For the first item, the shop around the corner wanted over 100 euros from me because they only had it from Sauer...
Translated on 08-07-2026, 2:11.
Post31-07-2008, 10:34    Subject: Timing belt replacement - tools for PD models Quote
The timing chain alignment tool usually comes with the timing chain kit anyway, so it's not worth buying, especially if you have the slightly newer tensioner. The lower part, which engages with the crankshaft sprocket, isn't worth 100 euros. The entire set from Hazet is significantly cheaper, and it's of good enough quality for 1000 timing chain replacements. After that, you probably won't want to do it anymore.
Translated on 08-07-2026, 2:12.
R00KIE
Post31-07-2008, 19:03    Subject: Timing belt replacement - tools for PD models Quote
I actually didn't want to do it again after seeing that, apparently, the employees of Ravensburger Puzzleschmiede were allowed to choose the location for the right engine mount.
No new posts Timing belt replacement for transversely mounted PD engine Troubleshooting & Guides
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts V6 TDI Timing Belt Replacement, AFB Diesel Engine Technology
No new posts Timing Belt Replacement 1 Diesel Engine Technology
No new posts Timing Belt Replacement for Audi VW Fiat Diesel Engine Technology
No new posts Timing belt replacement AJM Diesel Engine Technology
