ESP Problem beim Golf 4 ARL 4 Motion | Posts 32+
Go to page: Previous  1, 2, 3
Herr Antje
Post08-05-2006, 14:07    Subject: Quote
Thank you, Sebastian!
Ross-Tech-Support wrote:
According to the vehicle identification number, you have a Passat. This model does not use a Conti/Teves MK60 ABS system, but rather a Bosch 5.3 or 5.7 system, which does not offer any of those specific "options."
2) That is exactly the problem that is described in the KD solution - if I remember correctly, it was described there as a problem related to the alignment of the powertrain.
1) Too bad, but I can live with it. With my old A3, I had the feeling that it adjusted earlier, so it's okay. I also need to be a little careful with my tires icon_smile.gif.
2) This explains the different levels of intervention. But shouldn't this principle always be present, and is it only "masked" by the reprogramming? We're not actually changing the alignment of the powertrain, nor are we simply increasing the values on one side.
Well, the pa-mm6 was helped. I'm just asking out of pure interest. So, no one here needs to break their head over it for my sake... icon_cool.gif
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 30-08-2026, 9:17.
Ross-Tech-Support
Post10-05-2006, 10:47    Subject: Quote
Herr Antje wrote:
But in principle, it should always be present, and the reprogramming only "masks" it?
As far as I understand, yes.
Translated on 30-08-2026, 9:18.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post12-03-2008, 21:09    Subject: Quote
As the new ABS coding, including the bad road package, it is: 0023174
Hello.
I'm experiencing the same problem again with a friend's car. It's a Golf 4 Variant, manufactured in 2003, with a 101 HP TDI engine.
The current coding for the ABS ESP MK 60 front, part number 1C0 907 379 M 102, is 0019458.
It would be great to also incorporate the "bad road" encoding here.
Is there perhaps a table somewhere where one can calculate the encodings?
Sure, here's the translation:
"Thank you very much in advance."
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which means "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 30-08-2026, 9:20.
Back to top Profile PM Email
pa-mm6
Post21-03-2008, 19:30    Subject: Quote
Hello.
Can anyone help me?
Audi SQ5 8R Cvub
Translated on 30-08-2026, 9:21.
orso-ch
Post14-08-2008, 20:49    Subject: Quote
If a malfunction of the sensors, etc., can be ruled out, you should try changing the coding for the low-traction suspension, if necessary... icon_cool.gif
Hello.
Ich habe mich eben registrieren lassen, um die Gelegenheit zu haben, mich bei euch für den Ratschlag die Codierung auf Schlechtwegefahrwerk zu ändern, herzlich zu bedanken. Ich fahre einen Golf Variant Generation 4 Motion 130 PS TDI BJ 2001 und hatte wie pa-mm6 das gleiche Problem erstmals letztes Jahr 2007 im Sommer festgestellt (Bridgstone ER 300 205/55 R16 V). Als ich im Winter wieder auf Goddyear UG-7 195/65 R15 T gewechselt hatte, war das ESP Problem in der Linkskurve weg. Dieses Jahr kaum hatte ich die Bridgstone vom Vorjahr drauf, hatte ich wieder das gleiche Problem mit dem ESP in der Linkskurve. Als ich dieses Frühjahr auf diesen Beitrag gestossen bin, habe ich meiner Garage das Problem geschildert. Natürlich hat sie nichts Fehlerhaftes gefunden. Aber wenigstens hat sie auf meinen Wunsch das Steuergerät auf Schlechtwegefahrwerk umprogrammiert und tatsächlich das ESP-Problem war weg. Auf meiner Ferienreise nach Apulien, Italien, km 1300 hin und zurück) hatte ich genügend Möglichkeiten mein Auto in jeder Linkskurve zu testen. Ergebnis: Das ESP funktionierte einwandfrei. Ich konnte die Kurven sogar noch schneller fahren als vor dem Auftauchen des ESP-Problems. NoThank you very much.
bear-ch
Translated on 30-08-2026, 9:22.
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documented clutch failures in 4-Motion TDI-PD engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: GRA Failure When Turn Signal Is On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 ARL: Installing a Parking Heater On-Board Diagnostics (OBD)
No new posts H&R Anti-Roll Bar for VW Golf 4 4Motion: Does it work? Transmission, Chassis, Body & Interior
No new posts PDC Golf 5: Troubleshooting Parking Sensor Calibration Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf 5 2.0 TDI 4-Motion rear brake caliper Transmission, Chassis, Body & Interior
