Error 17755 & 18256: Troubleshooting & Test Box 1598/31
derkater
Post19-09-2008, 14:05    Subject: Error 17755 & 18256: Troubleshooting & Test Box 1598/31 Quote
Dear forum,
My van (T4 V6, with a Bigas system) is causing me trouble again since my last vacation trip:
It starts with a delay, then runs on gasoline in a truly unacceptable manner; it's barely able to move, but only as long as it's not running on gas. Therefore, the following standard message may not be related to this issue at the moment:
17755 - Bank 2; Camshaft position sensor (G163) / Crankshaft position sensor (G28): Incorrect assignment.
P1347 - 35-10 - - - Intermittent.
To check the sensor, the repair manual suggests using a sensor test procedure. It specifies using a VAG test box, which I don't have. How can I perform the necessary checks as an alternative?
Edit: The question regarding MWB 208 ff. has been resolved, as it is included in the RLF.icon_rolleyes.gif
Among the other, sometimes isolated, error messages:
17559 - Bank1; Mixed adaptation area 1: Lean limit exceeded.
P1151 - 35-10 - - - Intermittent.
17978 - Engine control unit locked.
P1570 - 35-10 - - - Intermittent.
"The following undocumented message was also displayed for the first time:"
18256 - Please read the error memory of the engine control unit.
P1848 - 35-10 - - - Intermittent.
In the latter case, the ESP light was on.
Can someone offer a constructive comment?
Thank you and best regards,
Stephan.
Translated on 13-10-2026, 20:31.
No new posts P0148 - Fuel Supply Malfunction General Tips
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AAT Error? Milk Replacer Feeding Questions. Diesel Engine Technology
No new posts ASR Issue: Audi 8D/B5 Questions On-Board Diagnostics (OBD)
No new posts MWB 11: Questions and Answers On-Board Diagnostics (OBD)
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
