Motor Control Unit Connectors: Order Now!
Octavia_4x4
Post03-10-2008, 17:48    Subject: Motor Control Unit Connectors: Order Now! Quote
I need a part number for repair cables and/or individual flat connectors for the engine control unit (ECU) connector.
Is it possible to order this through VW? Does anyone have experience with that?
"Because I need to retrofit the GRA (presumably referring to a specific system or feature) on a customer's Ibiza next weekend, and according to my information, I need to connect directly to the engine control unit (ECU) using a 4-pin connector."
Okay, I'll translate that for you. It's about the 1.9 TDI ALH engine, and I'll read the engine control unit (ECU) number later.
Translated on 02-09-2026, 4:02.
Trecker Treiber
Post04-10-2008, 15:57    Subject: Motor Control Unit Connectors: Order Now! Quote
Hello.
So, as I did with my A6, I went to a junkyard and looked for a connector with the appropriate contacts. On the old A6, the contacts were the same as those from the light switch of a Golf 2, if I remember correctly.
And that was it, all done.
Translated on 02-09-2026, 4:03.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post04-10-2008, 16:01    Subject: Motor Control Unit Connectors: Order Now! Quote
My mechanic has the yellow repair lines in stock. No part number needed.
edit:
I have a bag containing a set of wires with the number: 000 979 133. The set includes 5 wires, each 1mm in diameter.
Unfortunately, there are flat and round cable connectors, and I can't tell which one the number refers to. icon_rolleyes.gif
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 02-09-2026, 4:04.
michiglaser
2007 Audi A4 Avant
Post06-10-2008, 9:04    Subject: Motor Control Unit Connectors: Order Now! Quote
If you have the part number of the connector, the dealer (if they are knowledgeable icon_wink.gif) should be able to find the correct repair cables without any problems.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Wiesel
Post06-10-2008, 9:49    Subject: Motor Control Unit Connectors: Orderable? Quote
Ibiza1986 wrote:
...This is about a 1.9 TDI ALH engine; I'll read the engine control unit number later.
It would be helpful icon_wink.gif.
The problem is that there were ALH engines with MSA15.7 and EDC15V ECUs.
For the EDC15, the small connectors are already integrated into the connector housing (contact blocks).
For the MSA15, the contacts are individual contacts (000 979 131 / 000 979 131 A; the "A" version is gold-plated).
Best regards, Micha.
Translated on 02-09-2026, 4:05.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG connector contacts. Electrical Systems, Vehicle Electronics, Multimedia
No new posts Antenna Connectors: Buy Single Units. Transmission, Chassis, Body & Interior
No new posts VW MFD Rotary Knobs: Source & Buy Now Transmission, Chassis, Body & Interior
No new posts Pump Cable: Cheap Tuning for Your Pump Diesel Engine Technology
