Now, it's "me" who's affected. My AWX engine has a hole in a piston crown, and the cylinder walls are also damaged. Since the engine now has over 200,000 km, I'm going to install an AVF engine. (AVF because it's currently available). Now, my question: Can I continue to use the engine control unit from the AWX without any restrictions or software changes?
vagtuning said the following in another thread:
For control units with the following numbers:
038 906 019 EN
038 906 019 EP
038 906 019 ER
Should the PDEs with index AL or AR be installed?
"At"
038 906 019 GT
038 906 019 GQ
038 906 019 GR
The PDEs with index BA should be used.
Does anyone have information about my car with the license plate 038 906 019 JQ?
Does the gearbox actually fit?
If my memory serves me correctly, an AWX engine always had a 5-speed gearbox, while an AVF engine had a 6-speed gearbox!
