Engine Misfire: Get a Professional Diagnosis
moby
Post18-10-2008, 16:04    Subject: Engine Misfire: Get a Professional Diagnosis Quote
Hello, I have uploaded https://community.dieselschrauber.org/en/viewtopic.php?p=138295 diagrams showing the comparison of sensor values 13/18/23 with a cold/warm engine and with the air conditioning system active/inactive. I hope that the diagrams clearly show the cause of the defect (rough idle).
Thank you.
moby
Translated on 09-09-2026, 22:54.
Post25-10-2008, 10:02    Subject: Engine Misfire: Get a Professional Diagnosis Now Quote
Based on this information, I can only see that cylinder 3 consistently has a slightly higher correction value, but it's still within the tolerance range (+/- 2.8 mg, if I recall correctly). It's impossible to determine whether this is due to poor compression or partially clogged injectors.
MWB 18 and 23 are normal.
It's important to always log the PDE-Check-MWB data along with MWB1, so you can see the current engine speed and (average) injection quantity. The fact that only 2 MWB (besides 1) are available is a system limitation.
Translated on 09-09-2026, 22:55.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Misfire: 2.4L & 2.8L Motors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MWB 3 & 11 MKB ASZ: Evaluation/Review On-Board Diagnostics (OBD)
No new posts Log File Analysis: Review Request On-Board Diagnostics (OBD)
No new posts Chip Tuning: Yes or No? (MWB 3-8-11) On-Board Diagnostics (OBD)
No new posts Jerky idling Diesel Engine Technology
