ESP error sensor for yaw rate, Golf IV (G202)
Tribu
Karma: +3 / -2   Thank you, like it!
Post21-09-2008, 9:02    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Dear fellow enthusiasts,
Here's the translation:
"I'm experiencing the following issue. Since installing a sports suspension and 18-inch wheels, the ESP (Electronic Stability Program) is intervening too quickly, even on slight bumps. It seems to be happening even on straight roads." It's hard to understand.
If things get really bad, I also get an error message.
->> Encoder sending an implausible signal (I need to check the laptop for more details).
Driving slowly can be dangerous. The other day, on the highway at about 170 km/h, I was entering a turn and heading towards an exit, and that stupid ESP kicked in ---> frustrating!
Well, maybe someone can find it useful. I will post the original error message tonight.
Address 03
Control unit: 1C0 907 379
Component: ESP 20 CAN V005
Encoding: 18945
Shop #: WSC 01317
"1 error found:"
01542 - Rate sensor (G202)
27-10 - implausible signal - interrupted.
Sure, here's the translation:
"Thx" is a shortened form of "thanks." It's often used in informal online communication, such as text messages or social media posts.
vagtuning
Post21-09-2008, 11:49    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
A complete car scan, including any error messages, would be very helpful.
Tribu
Post21-09-2008, 20:38    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
And as described here, here is the entry again. It can get really dangerous sometimes.
Address 03
Encoding: 18945
Shop #: WSC 01317
"1 error found:"
Here's what I found in the database:
01542
Unlikely signal from the G202 rotation rate sensor.
Interruption, short circuit to positive or ground in the wiring.
The installation orientation of the G202 rate sensor is incorrect.
Encoder for axis G202 is defective.
Okay, found it icon_sad.gif. The transverse acceleration sensor is broken -> Approximately 500 Euros!
Thank you. Does VW ever stop [doing something]?
Post22-09-2008, 6:26    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
And did that happen while changing to the new tires? Almost simultaneously? Then I'm going to say that it's probably not due to a faulty sensor...
Tribu
Post22-09-2008, 8:54    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Yes, so it started there and got worse.
Meanwhile, it simply goes straight ahead on a straight road icon_sad.gif.
It's probably a common issue with Golfs/Boras.
Post22-09-2008, 9:19    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Right off the bat: I have no idea about ESP.
I'm still wondering why the drive shaft failed at the same time as the suspension was installed. That's why I'm asking: Are the tires identical on the front and rear? Is the lowering (if any) the same at the front and the rear?
"The reason I'm asking is: Did you perhaps build something with a wedge shape that might cause the installation position of the rotary sensor to no longer be within the specified tolerances?"
As I said: This is just an idea, and I don't have the necessary background knowledge regarding the installation and tilt tolerances of the rotary encoder.
Guste.
vagtuning
Post22-09-2008, 10:45    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Perhaps it's enough to simply recalibrate all the sensors.
the current suspension setup.
Tribu
Post22-09-2008, 21:24    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
hi...
Well, there's no wedge in it now. It's actually a really humane kind of tuning. H&R lowering springs, only 35mm, otherwise not too bad. I'm running a very high tire pressure, but it probably isn't that.
It also says that the donor is disconnected. I've often read that they are poorly soldered. "There have been people who managed to re-solder it (but the solder has already been used up)."
Okay, I'm going to order a new one tomorrow, but how do I learn to use it? Steering angle sensor is easy, but what about the sender?
@ OT ---->>> How do I learn to use this thing?
Thank you for your help icon_biggrin.gif.
Post23-09-2008, 6:32    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
It's strange, I've never heard of these things breaking. You never stop learning.
Tribu
Post23-09-2008, 21:41    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Yes, I was at VW today, and they are aware of the problem. Something probably changed around 2003.
It costs me 456,- icon_biggrin.gif hehe.
Well, I'm going to get one from eBay.
Regards...
Tribu
Post05-10-2008, 17:15    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Hello everyone...
Here's a short, funny story.
Today, being bored, I was installing electrical wiring and had to run a cable through the firewall when I encountered a completely loose part.
Well, just around the corner, and what was that?
...the sensors for rotary encoders and longitudinal acceleration (G200 + G 202).
Well, it's unbelievable that something like that would just come loose; he was diligently working on it. It's no wonder that he started making mistakes more frequently.
I should have looked earlier.
Post05-10-2008, 18:17    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Well, debugging can be quite tiring for some people...
Freddy2287
Post11-10-2008, 23:49    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Can you tell me where this plug is located? Because I have the same problem: At first, it was only happening sporadically, but now the ESP also intervenes randomly while I'm driving - which can be really dangerous? icon_rolleyes.gif
Tribu
Post28-10-2008, 22:42    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
Sorry, I read this late.
It's easy to access the area beneath the steering column from below.
Freddy2287
Post29-10-2008, 7:28    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
No problem - the ESP is currently permanently disabled.
Under the steering column? But exactly where? And is the sensor located there as well?
Tribu
Post29-10-2008, 22:20    Subject: ESP error sensor for yaw rate, Golf IV (G202) Quote
It's located directly on the steering column, approximately in the middle of the footwell, and is attached with screws from the right side in the case of a Golf. Unfortunately, I can't be more specific. However, if your ESP is completely turned off, there should be an error message.
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Error 01435: Golf 1J MJ 2001 Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 2.5 TDI ACV Error: Throttle Position Sensor Diesel Engine Technology
No new posts Exhaust Gas Recirculation Sensor Error T6 15560 Diesel Engine Technology
No new posts Oil level/temperature sensor On-Board Diagnostics (OBD)
No new posts Intake Manifold Pressure Sensor Problems Diesel Engine Technology
