08-10-2007, 16:43 Subject: Vintage Pressure Gauge & Load Cell |
Hi.
Are there any adjustment options or instructions available for the way-finding system of the VTG G581?
Could it be due to its position that my turbocharger is building boost so slowly?
Other companies (BNM, BUZ) are much faster in this regard.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 16-08-2026, 20:00.
Profile PM Garage |
Malte1408 Schrauber
Joined: 06/23/2005 Posts: 427 Karma: +12 / -0 Location: Hannover
08-10-2007, 17:21 Subject: Vintage Pressure Gauge & Load Cell |
Quote: |
Could it be due to its position that my BMR is so slow in building up the boost pressure? |
In principle, yes, assuming that the concept involving the position sensor no longer uses pulse width modulation (PWM) for control. Instead, it truly uses a position feedback signal, which is regulated based on the position sensor's output.
Adjusting the position of the sensor would have a similar effect to using a longer or shorter rod, but with greater precision and long-term stability.
If it only does something as simple as providing more sophisticated error detection, then probably not.
I don't believe there are any adjustments made in the customer service department for this. The initial settings are usually done by the loader manufacturer together with VTG, using a wind tunnel.
Translated on 16-08-2026, 20:02.
RTDI-Tom Guest
04-11-2008, 19:48 Subject: Vintage Pressure Gauge & Load Cell |
'Is it correct that older PD-TDIs did not have such a sensor? In other words, the variable geometry turbocharger (VTG) duty cycle that I can log in my ARL using diagnostic tool 11 is not an actual value, but rather a target value set by the engine control module (ECM).'
That would mean that with this type of air-to-refrigerant heat exchanger (ARH), even if the logged value shows 50%, I can't be completely sure that the VTG (variable geometry turbine) is actually at 50% (e.g., if it's stuck). Therefore, a jammed VTG or an error in the vacuum system cannot be diagnosed solely by looking at the duty cycle; instead, it must always be assessed by considering the duty cycle in relation to the actual boost pressure value. Am I understanding this correctly?
Translated on 16-08-2026, 20:04.
Malte1408 Schrauber
04-11-2008, 20:48 Subject: Vintage Pressure Gauge & Load Cell |
Quote: | | Is it correct that the older PD-TDIs did NOT have such a sensor installed? |
Yes.
Quote: | | The VTG key ratio that I can log in my ARL on the MWB 11 is not an actual value, but a target value specified by the MSG. |
Neither nor; it is the control variable.
http://de.wikipedia.org/wiki/Stellwert
Quote: | | This would mean that with this ARL, if I see a logged value of, for example, 50%, I cannot be completely certain that the VTG is actually at 50% (if, for example, it is stuck), right? |
absolutely correct.
Quote: | | I would therefore NOT be able to diagnose a stuck VTG (Variable Turbine Geometry) or an error in the vacuum system solely by observing the duty cycle, but always by considering the duty cycle in relation to the actual boost pressure value. Am I understanding this correctly? |
Yes, half. You should also consider the existing "exhaust energy."
Translated on 16-08-2026, 20:06.
RTDI-Tom Guest
04-11-2008, 21:07 Subject: Vintage Pressure Gauge & Load Cell |
Neither nor, it is the setpoint.
The actual and target value for this control variable is the boost pressure itself... Regarding the VTG (Variable Turbine Geometry) itself, I believe we can already speak of a 'target VTG value.' To avoid violating any process control definitions, perhaps we should simply call it a 'VTG specification.' Agreed?
What was important to me now was just the information about whether my accident report (ARL) provides any feedback regarding the current location of the VTG (presumably a vehicle or piece of equipment). However, it seems that is not the case.
Translated on 16-08-2026, 20:08.
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
05-11-2008, 9:16 Subject: Vintage Pressure Gauge & Load Cell |
Translating... |
Profile PM WWW Garage |
RTDI-Tom Guest
05-11-2008, 9:41 Subject: Vintage Pressure Gauge & Load Cell |
Thanks for the information! I already understand how a regulation works – that's something we go over and over again in engineering studies. My question, as I said, is simply this: Does the logged value represent the control variable that the MSG determines and passes on to the N75 and membrane dosage (and unfortunately, we have no idea what those two components do with it), or does the value reflect the actual position of the VTG?
I think the question has been sufficiently answered.
Translated on 16-08-2026, 20:10.
