Memory Seat Malfunction: Control Unit Issue?
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post18-11-2008, 11:56    Subject: Memory Seat Malfunction: Control Unit Issue? Quote
I'm having a problem with my Allroad, manufactured in 2001.
The seat memory function is not working on the passenger side.
I have observed all the values using VAg-COM, and all functions are displayed correctly.
This means the seating position is displayed accurately and changes when adjusted.
"When I operate the buttons on the seat memory switch, everything displays correctly. For example, when I press the On/Off button, or when I tap the individual memory buttons from 1 to 3, 100, 010, or 001 is displayed respectively."
Alone, it doesn't make a sound.
Could it be that the ECU (Engine Control Unit) has a fault, but it's not being displayed?
I know this story isn't tragic.
But people generally prefer to have a car that works icon_wink.gif.
Sure, no problem! Here's the translation:
"Thank you in advance!"
Translated on 23-09-2026, 3:33.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty T4 engine control unit, 2.5 TDI ACV On-Board Diagnostics (OBD)
No new posts Defective Control Unit: What to Do? On-Board Diagnostics (OBD)
No new posts Faulty Control Unit: Diagnosis & Repair On-Board Diagnostics (OBD)
No new posts Caddy 2.0 SDI: Faulty ECU? Diagnose & Repair. Diesel Engine Technology
