Spark Plug Problem: Electrical Fault Diagnosis
Benni
Post24-01-2009, 16:28    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
Hey everyone,
My Passat is giving me the following error:
Code:
Adresse 01: Motor
   Steuergerät-Teilenummer: 038 997 016 K
  Bauteil und/oder Version: R4 2,0L EDC G000SG  0092
1 Fehler gefunden:
17055 - GlĂźhkerze Zylinder 1 (Q10): elektrischer Fehler im Stromkreis
            P0671 - 000 -  -
             Umgebungsbedingungen:
                    Drehzahl: 0 /min
                    Drehmoment: 204.0 Nm
                    Geschwindigkeit: 0.0 km/h
                    Last: 0.0 %
                    Spannung: 11.63 V
                    Binärwert: 00101100
                    Temperatur: 0.0°C
                    Binärwert: 00110000
Readiness: 0 0 1 0 1
We replaced the glow plug yesterday, but unfortunately, the problem is still there.
Does anyone have any ideas about this?
Sure, no problem. Here's the translation:
"Thank you in advance."
Passat Variant Highline 3BG EZ 2/04 2,0 TDI mit DPF 235tkm 2x DPF gespĂźlt - RIP dank LKW
Translated on 23-07-2026, 11:50.
Post24-01-2009, 16:34    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
It's probably obvious, but has the error memory been cleared already? Otherwise, connect a multimeter and check where the problem lies.
Was ist mit der "richtigen" GK passiert? / Has the "correct" GK already been installed?
Translated on 23-07-2026, 11:51.
Benni
Post24-01-2009, 16:47    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
Yes, it was the correct candle.
I cleared the memory, but after a diagnostic test of the actuators, the error reappeared in the memory, and then a few days later, the emissions warning light came on.
Okay, then we'll start measuring things and maybe swap some parts; hopefully the new one will work.
Are there any other typical mistakes that occur there?
How are the candles controlled? Directly from the main system (MSG), or does it have its own control unit for that purpose?
Translated on 23-07-2026, 11:52.
Post24-01-2009, 18:18    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
Possibly, the glow plug control unit is faulty.
The question is, what exactly does "electrical fault in the circuit" mean? It could indicate a failure of the main control unit, a short circuit to ground, or an open circuit. icon_question.gif
Try using a different GSK and see what error message appears.
Translated on 23-07-2026, 11:53.
Benni
Post31-01-2009, 8:19    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
*cough*
Yes, it's a little embarrassing, but I'm going to write it down anyway.
Upon inquiry, I was told that cylinder 1 is the one at the front near the timing belt, but that's actually cylinder 4.
Yesterday, I disconnected the connectors from both cylinder heads to the belt, and that's when I discovered that I had 3 "faulty" glow plugs.
Okay, so I guess I'll probably replace the spark plug on the rear cylinder, near the injection nozzle; that might solve the problem. *g*
Should I do them all at once? I've heard different opinions about it so far.
@Rainer, thanks again.
Translated on 23-07-2026, 11:54.
vagtuning
Post31-01-2009, 12:56    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
*cough*
Just to reiterate, Cylinder 4 corresponds to the first timing belt pulley, correct?
Translated on 23-07-2026, 11:56.
BM
Avatar-BM
Post31-01-2009, 15:54    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
Okay... I replaced all the glow plugs in my AJM engine a few days ago.
- Engine: 2 out of 4 defective.
- Glow plug heater: 3 out of 3 defective.
Generally speaking, I've found that in almost every vehicle, at least two components have failed after approximately 180,000 km or 5-8 years, and it's even possible for this to happen sooner.
My advice: if one fails, replace them all.
3B5 AJM
Translated on 23-07-2026, 11:57.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post31-01-2009, 17:38    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
I only replaced it once at 70,000 km (although it was a 5-volt spark plug, specifically the GE 100 for a Touran).
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 23-07-2026, 11:58.
Benni
Post01-02-2009, 14:07    Subject: Spark Plug Problem: Electrical Fault Diagnosis Quote
vagtuning wrote:
Benni wrote:
*cough*
Just to reiterate, Cylinder 4 = the first timing belt – is that correct?
That's what the error memory told me when I removed the spark plug connectors (specifically, the two front ones, as they were easiest to reach).
Then cylinders 1, 3, and 4 were identified as faulty.
I'd be happy to test that again.
Translated on 23-07-2026, 11:59.
No new posts Electric auxiliary heater, smell of burning, Audi A4 A5 Q5 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts NOX Bank1 P2200 - Electrical Fault On-Board Diagnostics (OBD)
No new posts RNS E: 16352 - Steuergerät - Electrical Fault 014 - Defect On-Board Diagnostics (OBD)
No new posts Polo Glow Plug Error: Get Help Now! Diesel Engine Technology
No new posts Spark plug fouled! Diesel Engine Technology
