marco_A4_avant
Joined: 11/13/2008 Posts: 9 Karma: +0 / -0 Location: Altenstadt 2000 Audi A4 Avant Free account, no CAN development support
03-02-2009, 21:05 Subject: Power loss from 2200 RPM... 1.9 TDI PD |
Hello! I drive an A4 1.9 TDI PD with 115 horsepower. For some time now, I've noticed a loss of power starting around 2200 RPM. When I turn the engine off and then on again, it runs well again. Today, I had the error codes read, and this is what came up:
Error code -> Motor -> Motor electronics I.
Error code: 17965
LABEL PRINTING
-INTAKE MANIFOLD PRESSURE TOO HIGH
-sporadic error
Has anyone had similar experiences, have any suggestions for solutions, or just a tip about what might be causing this?
ps: I've just installed a new LLM, and that's not the problem.
"Thank you."
Best regards. Schöne Kombis heißen Avant
Profile PM Garage |
kuestenkuddel Guest
03-02-2009, 21:27 Subject: Power loss from 2200 RPM... 1.9 TDI PD |
Hi Marco,
Have you ever tried searching for 'Error code: 17965'?
And what? Is there nothing for you?
Best regards, Kurt.
schrauber84
04-02-2009, 9:27 Subject: Power loss from 2200 RPM... 1.9 TDI PD |
Have you checked for any leaks, or if a hose might be faulty?
