matthiasTDI96 Profi-Schrauber
17-02-2008, 12:36 Subject: Auxiliary Heater T5: Activation Conditions Changed |
The T5 vehicle automatically activates its diesel-powered preheating system at these outside temperatures until the coolant temperature reaches a sufficient level.
Da dies ja auch auf Kurzstrecke passiert, wäre ein Deaktivieren der der Heizung bei bestimmten Fahrten ja sehr sinnvoll. Leider kann der T5 das nicht über Schalter im Cockpit leisten. Bei https://community.dieselschrauber.org/en/viewtopic.php?t=20317
I only find options for unlocking and locking. I also think a permanent deactivation wouldn't be a problem. Are there any ideas on how to do that?
Translated on 03-09-2026, 8:03.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
17-02-2008, 16:49 Subject: Auxiliary Heater T5: Activation Conditions Changed |
My old, new idea is:
Switch the indoor control panel to "Summer" mode to adjust the settings based on the external temperature sensor.
- I did that on an Alhambra.
Edit: A permanent deactivation is not ideal via OBD, but can be easily solved using a switch. Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 03-09-2026, 8:04.
Profile PM Email Garage |
17-02-2008, 21:47 Subject: Auxiliary Heater T5: Activation Conditions Changed |
Well, the goal was to avoid something like that "act of violence"...
Something else is needed.
I've had that idea before, but I don't want to solve it that way.
Translated on 03-09-2026, 8:05.
17-02-2008, 22:02 Subject: Auxiliary Heater T5: Activation Conditions Changed |
I already suspected that, but isn't that also "digital": on/off, finished, and that small cable, if it's connected to a nice, original switch...  Gruß, der Teileklaus
18-02-2008, 8:42 Subject: Auxiliary Heater T5: Activation Conditions Changed |
Okay, I still want to get this part working like a regular auxiliary heater... maybe they're working on a solution. The frustrating thing is that it can't be turned off. The user manual says it should be deactivated using the "Econ" function of the climate control system, but that seems to be a lie... because when you open the door, you can always smell and hear the oil heater working right underneath the car!
Translated on 03-09-2026, 8:06.
12-02-2009, 13:16 Subject: Auxiliary Heater T5: Activation Conditions Changed |
I noticed that the auxiliary heating function was no longer available when using the "Econ" mode in the Touran. Gruß, der Teileklaus
Translated on 03-09-2026, 8:07.
