Piezo Injectors: 3.0 TDI - Installation & Problems
vwSchrauber
Post13-02-2009, 12:31    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
Does the current 3.0 TDI engine already use piezo injectors, or are they still using solenoid valves?
Greetings.
John.
Translated on 03-09-2026, 23:28.
Post13-02-2009, 12:42    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
Sure.
They are piezo elements.
vwSchrauber
Post13-02-2009, 13:16    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
"Thank you!"
Has this been the case since the 3.0 versions, or only with the latest generation?
Post13-02-2009, 15:27    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
As far as I understand SSP351, it's been around for a while. The 3.0CR, on the other hand, isn't that old.
Translated on 03-09-2026, 23:29.
vwSchrauber
Post13-02-2009, 17:10    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
just found -> http://www.audi.at/motoren.php?K_ID=59
However, they don't reveal much information.
provide power that unfolds spontaneously and energetically. This means: active reserves of performance and sovereign elasticity
It certainly says a lot about the engine icon_evil.gif - I would also expect a 3.0-liter engine to have good acceleration.
I find the 1800 bar mentioned there strange - didn't the 3.0 have a second-generation common rail system? - or is it a "marketing exaggeration"?
"Does anyone happen to have an engine control unit (ECU) file for a 3.0 TDI engine? I'd like to take a look and see what's actually programmed into it."
Translated on 03-09-2026, 23:30.
Post13-02-2009, 17:20    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
I can offer "EDC 16 CP" and "up to 1600 bar" for the 3.0.
The 2.0 CR refers to "EDC 17" and "1800 bar".
And since the Audi page for "Audi A6 TDI Engines" mentions "up to," everything is correct icon_smile.gif.
Translated on 03-09-2026, 23:31.
vwSchrauber
Post13-02-2009, 17:21    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
Oh, so - they're already installing EDC17 systems icon_eek.gif now.
Translated on 03-09-2026, 23:32.
Tobi12345
Post13-02-2009, 17:53    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
I sent you a short private message.
Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
christians
Post14-02-2009, 17:13    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
It has had piezo injectors from the beginning.
Gruß Christian
vwSchrauber
Post16-02-2009, 9:12    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
Thank you!
vwSchrauber
Post16-02-2009, 15:51    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
Just checked - in the current 3.0 TDI engine with EDC17, the maximum pressure is exactly 1650 bar.
Post16-02-2009, 16:06    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
3.0 TDI with EDC17
Translated on 03-09-2026, 23:33.
vwSchrauber
Post16-02-2009, 16:16    Subject: Piezo Injectors: 3.0 TDI - Installation & Problems Quote
Well, you're asking some interesting questions...
Software version is 390626, I'm afraid I don't know the MKB.
Edit:
Okay, I just checked for comparison: the 155/212 BNG EDC16 has a maximum pressure of 1600 bar.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CR Injector Conversion: Piezo to Magnet Explained Diesel Engine Technology
This topic is locked, you cannot edit or reply. Enter Piezo Injector :Pparameters using VCDS (3.0 TDI/BMK) Diesel Engine Technology
No new posts Piezo PD System: New Information and Details Diesel Engine Technology
No new posts Piezo Injector Test: Audi A6 4F Diagnosis Diesel Engine Technology
