Golf 3 TDI: Install Key Fob Remote Control
hollari
Post07-04-2006, 12:13    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
Hello!
I purchased a folding key remote control from www.mucola.de.
because the door lock on the driver's side is broken.
I've used the search function several times, but I haven't found anything relevant.
Therefore, I would like to provide a small 'installation guide' here:
Installation of receiver:
I installed the receiver behind the light switch.
To do this, the plastic parts above and below the steering wheel need to be removed.
Then remove the ventilation grilles in the center and on the left side, as well as the blind covers.
remove it, and take out all the screws.
Remove the light switch, then the bracket for the left side.
Remove the ventilation outlet.
Also, disassemble everything below the steering wheel as well.
The receiver should be placed under the light switch.
Secure this item firmly with a cable tie or similar. The antenna can be...
Route the cables neatly around the fixtures. (There's also very little metal there.)
(which could interfere with the reception).
Remove the jumper from the receiver. Handle the cables with care.
Connect it before installation, otherwise you will need a small...
Mirror, because the connector fits quite precisely. (Requires some fiddling).
The black cable should be connected directly below the steering wheel.
at the mass point (10mm open-end wrench).
Remove the fuse from the central locking system (number 21, the second to last one?).
Then, thread the following cables through the driver's side support:
Rot, Gelb, Gelb/Schwarz, GrĂźn, Blau, evtl. auch die beiten Violetten (f. Turn signal.
Make the following connections on the circuit board (this can also be done at connector 'A1095' if you can find it):
Recipient: _____________ Car: ______________________ Function:
Red + Yellow + Yellow Black ___ Red/White (Thicker cable) ___ +12V constant.
Blue___________________Gray_____________________To lock tightly.
Green___________________Green_____________________Unlock
Other cables:
Brown, Gray: Not required (these are the 'normally closed' connections).
BlauSchwarz: Not required (this may be used to control existing electric windows, if present).
Violet (2x), possibly connect to turn signals.
Rosa(?) Horn (questionable whether it's useful or even allowed?!?)
Added:
Of course, I connected the black wire to ground.
There's a screw on the metal panel under the steering wheel, and it already has a...
The cable is connected (presumably to the main electrical system?!).
Translated on 16-09-2026, 4:05.
Tdi-Cruiser
Post14-04-2006, 10:56    Subject: Mucola Installation: Golf TDI Guide Quote
Hello Hollari!
Thank you for the installation instructions; I'm facing the same challenge and have already prepared myself for a long afternoon, as one cannot really call it an installation manual icon_cry.gif.
As I understand it, you chose the second of the three installation options - is that correct?
Are you referring to the driver-side bracket as the rear connectors for the combination plugs that go to the door?
Regards, TDI-cruiser.
Bora Variant ASZ/FEL und säuft und säuft und säuft :-/
alt: G3 Variant - AFN/CYP und läuft und läuft und läuft icon_wink.gif
Translated on 16-09-2026, 4:09.
hollari
Post14-04-2006, 20:15    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
No. By 'driver-side strut,' I mean the cables under the plastic cover.
It has plenty of space, and you can easily connect everything.
But the cables continue into the door, and that's correct.
Please provide the text you would like me to translate. I need the text from the attachment to be able to translate it.
FotosEinbau.zip
 File name:  FotosEinbau.zip
 File size:  491.89 KB
 Downloaded:  26560 times
Translated on 16-09-2026, 4:10.
Tdi-Cruiser
Post16-04-2006, 9:37    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
Great!
Thank you for the photos; it makes the whole thing easier icon_wink.gif.
I once compared the wiring diagram for the Golf with your installation instructions.
If you directly connect the lines "on", "to", "+" and "-", it will be sufficient to inject the signal into the compressor unit icon_rolleyes.gif.
I'll try this out and give you feedback later.
Regards, TDI Cruiser.
Translated on 16-09-2026, 4:11.
hollari
Post16-04-2006, 22:26    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
@Tdi-Cruiser:
That was actually my plan, to install the FFB receiver directly on the compressor.
But unfortunately, I didn't know exactly where, and I didn't want to fill up the entire trunk.
disassemble. (Everything I have is covered with this kind of felt.)
I've already received a circuit diagram, and it mentions something about a...
Connection for an alarm system or something like that...
The connector is called 'A1095' and, according to my documentation, it also carries all the signals.
(excluding dimensions) that are required for the FFB.
If anyone knows where the plug is, please post it. If I'm not mistaken...
Could the FFB (Force Feedback Base) be installed here (with the appropriate adapter)?
that it can also be removed 'completely' and without a trace.
Sigi.
Translated on 16-09-2026, 4:13.
Tdi-Cruiser
Post17-04-2006, 20:18    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
@ Sigi, as requested, I installed the receiver on the compressor. It took about 30 minutes, including connecting the turn signal control. icon_biggrin.gif
I installed the cables with branch connectors from a specialized hardware store. It worked very well, and they can be removed relatively cleanly because the cables are only slightly scratched.
Regarding your question, the compressor is located in the rear right side of the Variant and Flowback models, in front of the taillight. You can easily connect the cables there.
Unfortunately, I can't provide any information about switch A1095.
Best regards, Simon.
Translated on 16-09-2026, 4:15.
hollari
Post17-04-2006, 22:01    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
Right rear = passenger side?
A1095 is not a switch, but a plug for a...
Factory-installed alarm system (probably doesn't have one).
That means the plug should normally be free.
Translated on 16-09-2026, 4:16.
Tdi-Cruiser
Post18-04-2006, 8:10    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
I obviously meant a plug connection, not a switch. It's clear that whoever writes what they think has an advantage.
Regarding the compressor unit: It's located on the right-hand side in the direction of travel, in the trunk, at the height of the taillights, between the taillights and the wheel arch - essentially, in the fender.
Translated on 16-09-2026, 4:17.
hollari
Post18-04-2006, 11:38    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
Could you maybe take some photos and post them?
Ross-Tech-Support
Post18-04-2006, 11:46    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
Just throwing that out there...
http://eleanor.tool-base.de/tuning/klappsch.htm
Tdi-Cruiser
Post19-04-2006, 8:01    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
@siggiViewing profile: siggi:
No problem. I can do it, but it probably won't be until the weekend.
Translated on 16-09-2026, 4:18.
CyberLine
Post04-05-2006, 21:21    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
Yes, hello first of all icon_biggrin.gif.
Thanks to your help, installing the FFB was a matter of just 15 minutes.
I just plugged it directly onto the back of the AC compressor, and that's it.
Lestat
Post05-06-2006, 18:32    Subject: SEO-Optimierter Titel: **"Best German SEO Agency | Top Rankings Guaranteed"** Quote
Could you please tell me which cables you have connected to which terminals in the entry-level area?
PLEASE.
I managed to get the turn signals and the horn working.
Translated on 16-09-2026, 4:19.
Poloprolo
Post31-12-2006, 16:04    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
Hello!
I'm new here, and I actually only signed up because of this interesting topic!
I have a Polo 1.4 TDI, manufactured in March 2000, and I also purchased the remote control from mucola.
However, I've now reached the limits of my abilities during the installation and connection process.
According to the installation instructions, there are several different systems: systems controlled by the positive terminal/systems controlled by the negative terminal, and then systems with either one or two control wires.
Since I have a compressor in the trunk, I was able to determine that I have two control lines based on the cables that connect to it there.
According to the cable list that mucola sent, I also found the following:
Central locking system type: Plus-controlled.
Cable color, central locking, power: white-green.
Cable color for central voltage: white-yellow.
Okay, so I've connected the blue wire labeled "Vehicle On" to the white-green wire, the green wire labeled "Vehicle Off" to the white-yellow wire, the black wire to ground, the red wire to constant positive, and both the yellow and yellow-black wires to constant positive as well.
I haven't connected the others, and I've removed the jumper.
If I now press "Close" on the remote control, I can hear a clicking sound from the device, but the compressor doesn't make a sound.
When I lock the car with the key fob and then press "unlock," the central locking system unlocks, but both front windows (power windows) also partially lower.
I've also tried connecting the yellow and yellow-black wires to ground, just like in a mass-produced system, but that doesn't work either.
Does anyone know what's causing my problem?
Did I possibly damage something by trying out the mass-based circuit?
Okay, I installed the receiver on the driver's side, near the fuses. I took the up/down wires from the passenger side, near the door opening, and ran them over. Before connecting them, I checked the wires with a voltmeter to make sure I had the correct ones.
Translated on 16-09-2026, 4:22.
SprintDriver
Post15-02-2009, 13:20    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
I also upgraded my Golf 3 with this FFB.
So far, everything is working perfectly with the central locking system, except for the comfort closing function for the electric sunroof, which is causing problems.
There is a connection on the black box for a comfort closing function, but unfortunately, I am unable to extract a signal from it.
Can someone who has also installed this FFB (Fanatec Formula wheel base) tell me if this is normal, or if only I am experiencing this problem?
The issue concerns the signal on the blue and black cable.
Sure, here's the translation:
'Thanks and greetings.'
Translated on 16-09-2026, 4:25.
SprintDriver
Post22-02-2009, 11:45    Subject: Golf 3 TDI: Install Key Fob Remote Control Quote
Problem solved.
Even Google couldn't find any information about it. I only figured it out after a lot of trial and error, and eventually by measuring the voltage at the different outputs.
Translated on 16-09-2026, 4:26.
No new posts A3 8L Remote Control: Troubleshooting & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Audi A4 Remote Control Installation: 1995 Model Diesel Engine Technology
No new posts Folding key is failing Transmission, Chassis, Body & Interior
No new posts Audi Folding Key with 2 and 3 Buttons Compatible? Transmission, Chassis, Body & Interior
No new posts Remote control malfunction On-Board Diagnostics (OBD)
