Wie erkennt man 30 oder 23 Byte (BordNetz und Abbiegelicht) | Posts 32+
Go to page: Previous  1, 2, 3
Post05-03-2009, 14:08    Subject: Quote
"No, I once tried to take something apart in the bus because of the cruise control... it's amazing how things can be installed. I just blindly stuck my long arm into the dashboard until the connector was in place."
Translated on 14-08-2026, 8:51.
Post05-03-2009, 14:22    Subject: Quote
I just checked the status of my 3C with a 30-byte High BnSTG.
Code:
Adresse 09: Bordnetz        Labeldatei: RKS\3C0-937-049-30-H.lbl
   Teilenummer SW: 3C0 937 049 AL    HW: 3C0 937 049 AL
   Bauteil: Bordnetz-SG     H54 2202
   Revision: 00H54000    Seriennummer: 01000007013612
   Codierung: E38A8F4701041A00470A00000F000000000F5D435C000100000000000000
   Betriebsnr.: WSC 05124 000 00000
   Teilenummer: 3C1 955 419 A
   Bauteil: Wischer 020507 003  0205
   Codierung: 00046997
   Teilenummer: 1K0 955 559 AB
   Bauteil: RLS     210507 020  0105
   Codierung: 00208933
According to the documentation, the turn signal should work even with fog lights on, but I didn't test it yesterday.
Regarding the TFL issue with Nebler: Unfortunately, the lenses are still rotating. So, it hasn't been fixed in the AL STG either.
Whether the turn signal light override feature works with fog lights is uncertain, as some other features that should work according to the documentation did not function correctly (e.g., changing phone number information services and roadside assistance contacts [control unit 77, A20+21], enabling voice control in the steering column electronics [control unit 16, C?xxxxxx]).
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 14-08-2026, 8:52.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Byte 18 again Electrical Systems, Vehicle Electronics, Multimedia
No new posts Polo 6R: Engine Byte 4 Not Set - Normal? On-Board Diagnostics (OBD)
No new posts VAG-COM does not recognize the control unit for the G40 On-Board Diagnostics (OBD)
No new posts A6 4B 2.5 TDI AKN: Identifying Facelift Models Transmission, Chassis, Body & Interior
