VW Problems: Reading Difficulties?
Boon
Post07-03-2009, 18:51    Subject: VW Problems: Reading Difficulties? Quote
Hello!!! I've already looked in the forum but couldn't find anything.
I have a VW Touran (year of manufacture 2005) and a Caddy (year of manufacture 2005) for which I want to reset the service interval or check the control units for any error codes.
But when I try to troubleshoot both of them, it only finds the engine control unit icon_sad.gif every time.
I have the "VAG-COM/OBD2 Diagnostic Professional System KKL+CAN (USB)," and according to the description, it should work. However, if no control units can be found, I won't be able to find any error codes or reset the service interval.
What am I doing wrong? Does anyone have a tip? Usually, everything works fine.
Best regards, Daniel.
Skoda Fabia RS (ASZ) Bj.9/2005
Translated on 05-08-2026, 20:37.
alsch
Post07-03-2009, 19:34    Subject: VW Problems: Reading Difficulties? Quote
Sure, ask away.
Which interface are you referring to, one from the landlord's shop?
Which version of VCDS?
alsch
Ford Focus Kombi
1,8er Benziner Bj 2000
0,0 Probleme, geht immer
Translated on 05-08-2026, 20:38.
Boon
Post07-03-2009, 19:43    Subject: VW Problems: Reading Difficulties? Quote
alsch wrote:
Sorry, first two questions:
I got everything from the diesel mechanic's shop.
I have version 805.2!!! But wait... I have the German version installed... I just read that the German version is only for professional systems or something like that. Could that be the problem?
Translated on 05-08-2026, 20:39.
alsch
Post07-03-2009, 20:50    Subject: VW Problems: Reading Difficulties? Quote
Please check the connection and logging settings in VCDS to see if any boxes are checked or if any settings are incorrect. You might want to try restoring the default settings.
alsch
Ford Focus Kombi
Translated on 05-08-2026, 20:40.
Post07-03-2009, 22:32    Subject: VW Problems: Reading Difficulties? Quote
Boon wrote:
I have 805.2!!! But wait... I have the German version installed... I'm just reading that the German version is only for professional systems in a case or something like that. Could that be the problem?
"That's ridiculous. The system wasn't delivered with Chinese installed, was it? Please read carefully and check in the VCDS under 'About...' to see which version and data status are installed, and then write it here."
Next, I would like to know the content printed on the label attached to the diagnostic cable.
Translated on 05-08-2026, 20:41.
Post07-03-2009, 22:35    Subject: VW Problems: Reading Difficulties? Quote
It seems the issue is resolved: According to the shop, you purchased a "Semi-professional EOBD/OBD2 diagnostic system KKL (USB)" in 2007.
The Caddy requires CAN communication.
I have the "VAG-COM/OBD2 Diagnostic Professional System KKL+CAN (USB)"
According to the shop, you neither purchased nor received the item?
Translated on 05-08-2026, 20:42.
Boon
Post08-03-2009, 14:39    Subject: VW Problems: Reading Difficulties? Quote
I'm sorry. Then that was my mistake... I was actually quite sure otherwise I wouldn't have created the post icon_redface.gif.
Translated on 05-08-2026, 20:43.
Post09-03-2009, 11:03    Subject: VW Problems: Reading Difficulties? Quote
No problem, it's all sorted out now. However, for compatibility reasons, the engine control unit (ECU) in the Caddy can still be accessed via the K-line; otherwise, this wouldn't work.
Translated on 05-08-2026, 20:44.
No new posts Volkswagen T5, Innenleuchte/Bordnetzsteuergerät Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran 1T: Fueling Problems & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Volkswagen AG is spying?! Diesel Engine Technology
No new posts Quo vadis Volkswagen? (leicht ot) Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Volkswagen Caddy 9kv AYQ, no power Diesel Engine Technology
No new posts 1Z Turbocharger Problems: Boost Issues & Solutions On-Board Diagnostics (OBD)
