Climatronic Values: Original Data & Readings
alexso
Post25-05-2002, 17:31    Subject: Climatronic Values: Original Data & Readings Quote
Hello, fellow diesel enthusiasts!
I adjusted some setting on the Climatronic display in a...
1998 Passat AFN, 81 kW.
Since the adjustment, the indicator light has been flashing while I'm driving.
Does anyone have the original values or a website address?
Best, Alex.
Translated on 28-08-2026, 10:27.
rl2664
Post25-05-2002, 19:22    Subject: Climatronic Values: Original Data & Readings Quote
Hello Alex,
I don't think that has anything to do with the other. If there were a problem with the climate control system, the display would flash all segments when starting.
Let's read the error codes, then we'll know what the car is trying to tell us.
best regards
Ronny.
Translated on 28-08-2026, 10:28.
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error Code 04F7: Diagnosis & Troubleshooting On-Board Diagnostics (OBD)
No new posts VW Sport Suspension: Upgrade & Lowering Transmission, Chassis, Body & Interior
No new posts Original vs. Aftermarket Parts: Which is Best? Transmission, Chassis, Body & Interior
No new posts Log 3, 8, 11 Audi A6 2.5 TDI BDG, Manual Transmission (Or... Upload
