VW T4 Immobilizer Problem: Troubleshooting Guide
AD-Technik
Post20-02-2009, 22:25    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
Hello.
I'm new here and hope I've posted my question in the correct category.
Okay, my problem is that I bought a VW T4 2.5 TDI with 102 horsepower.
Unfortunately, the first major problem occurred upon delivery: it starts briefly and then shuts off again.
I suspected it was the immobilizer, which was confirmed to me by VW when I had the car towed there. They tried to reprogram the key, somehow online or something, but I don't know anything about that. However, it didn't work. They told me that the key wasn't communicating with the decoder or that the control unit wasn't being unlocked.
Okay, so my question is, is there any way to bypass the immobilizer, or can I troubleshoot the problem without having to spend 1200 euros?
Thank you for any feedback.
Translated on 18-10-2026, 21:23.
Post20-02-2009, 22:59    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
How is it possible that you bought a car with a blocked WFS (Vehicle and Traffic Information System)? The seller should have taken care of that! Or is the car stolen?
Translated on 18-10-2026, 21:24.
AD-Technik
Post21-02-2009, 12:56    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
"This is not stolen; it's from an insolvency case, and I believe the key is not original."
audi4b
Registered VCDS User
Post21-02-2009, 12:57    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
First, the cable connection of the reading head needs to be checked.
If the WFS control unit is defective, I would install a used one.
The price is around 50 euros.
What is the year of manufacture of the car?
Translated on 18-10-2026, 21:25.
AD-Technik
Post22-02-2009, 11:04    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
Hello.
The connection is okay.
I already had the vehicle checked at VW, and they said that the main control unit is not being unlocked. How does that actually work? Does the reading coil read the transponder values and pass them on to the immobilizer control unit, which then unlocks the main control unit? Is that correct?
Is the immobilizer control unit compatible, or does it have to be the exact same model? Is the control unit a separate unit, or is it integrated somewhere?
Can this perhaps be circumvented?
Oh man, it's 2000.
Translated on 18-10-2026, 21:26.
michiglaser
2007 Audi A4 Avant
Post22-02-2009, 13:37    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
The WFS control unit is located separately in the T4, to the right behind the speedometer.
It's possible that this part could also have been installed in a Golf 4 Cabrio, but I'm not sure if it would be compatible.
You won't find any tips here on how to bypass the WFS.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 18-10-2026, 21:27.
AD-Technik
Post22-02-2009, 16:40    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
I meant compatible in the sense that if I were to purchase a WFS control unit and the corresponding key transponder, would they work together, or do they need to be compatible with the main control unit?
audi4b
Post22-02-2009, 18:39    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
You only need the WFS control unit.
Then you still need to train it.
It can only be done with VAGCOM, but you won't have the login code for it.
Either you find someone who can read the login code for you, or you go to a VW workshop.
Translated on 18-10-2026, 21:28.
mullemaus
Post22-02-2009, 23:59    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
What is the year of manufacture of the car? icon_wink.gif Are there transponders in the keys? } Are these the keys to the car? }
AD-Technik
Post23-02-2009, 21:07    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
Year of manufacture: 2000. I don't know if the transponders in the receiver are original.
Translated on 18-10-2026, 21:29.
TurboMarco
Post25-03-2009, 21:03    Subject: VW T4 Immobilizer Problem: Troubleshooting Guide Quote
Is your problem already solved?
No new posts Intermittent immobilizer problem, Passat 3C Variant, 2009 On-Board Diagnostics (OBD)
