V6 TDI: No Power? Troubleshooting Guide.:-(
Frank F.
Post17-04-2003, 12:48    Subject: V6 TDI: No Power? Troubleshooting Guide.:-( Quote
Hello!
My V6 TDI (AKN, 3/99) has been underperforming lately. There are no error codes stored, but unfortunately, I don't have a VAG-COM diagnostic tool, and the original Audi dealer is being unhelpful. Can I check the MAF sensor without any diagnostic software? Yesterday, a new issue appeared: while driving in a curve, it simply stalled when downshifting. The maximum speed is now only 190 km/h (approximately 115 mph) with great difficulty! Tires are size 215/55/16, front-wheel drive.
Does anyone have any ideas?
Best regards, Frank.
Translated on 08-08-2026, 2:20.
kenny
Post17-04-2003, 14:46    Subject: V6 TDI: No Power? Troubleshooting Guide.:-( Quote
Try cleaning the LMM (likely referring to a language model) using the 'recipes' that have been described multiple times in the forum; it might help solve the problem!
If it suddenly stops working: check and possibly replace the fuel filter (especially if you've ever used biodiesel), or bleed the fuel lines.
Translated on 08-08-2026, 2:21.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Off: No More Soot? Diesel Engine Technology
No new posts No KAT? What happens then? Diesel Engine Technology
No new posts G3 AFN: No Boost Pressure After Inspection Diesel Engine Technology
No new posts ABS Failure: No MStrg Access, Other Issues Diesel Engine Technology
