...and don't forget to thoroughly clean everything behind the turbo, in the intake air duct, and possibly even clean the LLK (charge air cooler), as there will probably be half of the turbine wheel in fragments there.
Good luck
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
As a precaution, I replaced the air-to-water cooler, as well as cleaned and flushed all the lines. I'm taking extra precautions, as you mentioned that the remaining pieces of the fan blades were located in the air-to-water cooler! (I also didn't have to pay more than €150 for the air-to-water cooler.)
