Off-Road Code for Bora ASZ
Klapperkiste
Post05-04-2009, 16:03    Subject: Off-Road Code for Bora ASZ Quote
Hello everyone,
Since switching from winter to summer tires, I've been experiencing the familiar ESP (Electronic Stability Program) issue in left-hand curves. The ESP brakes me whenever I drive through left-hand curves at a slightly faster speed.
I suspect there's also a connection to the rear wheels. They have new tires on them, and even though they're the same size, they certainly have a larger circumference than the 'old' front tires.
The value of my 'rotation sensor' is -0.36 degrees when it's in a resting state. Is this value still within the acceptable range?
I read in this forum that it's possible to calibrate the sensor (or the entire ESP). Unfortunately, I have no idea how to do that. I'm using the VAGCOM 3 software.
Another solution would be to switch to the 'bad path' execution. In the forum, I found the code 0023174 for this.
Unfortunately, it doesn't work for me.
The default setting for me is the code 0019970.
Currently, I have the 0019458 code from the 101 PS TDI engine installed, but it also tends to overcorrect too early in left-hand turns.
Does anyone know the required code?
You're very welcome!
Bora TDI, Limited, ASZ engine.
Translated on 28-10-2026, 16:04.
Klapperkiste
Post14-04-2009, 17:34    Subject: Off-Road Driving Code Found Quote
Hello again,
I have now managed to figure out the code for the off-road driving function.
You only need to add 128 to the original code, and it becomes a 'bad path' execution icon_smile.gif.
Therefore, 0019970 icon_arrow.gif 0020098 becomes.
During the first test drive, the ESP system actually activated much later - I would say that the timing of its intervention is now justified.
Translated on 28-10-2026, 16:07.
No new posts Golf, Bora (from 05.00) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery drain troubleshooting for Golf IV and Bora Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Combination instrument, Golf, Bora, 05.99 to 04.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WFS Code: Definition and Examples On-Board Diagnostics (OBD)
No new posts Climatronic Problems: Codes 4F8 & 4B6 Explained On-Board Diagnostics (OBD)
No new posts Invalid Authorization Code: Causes & Fixes Dieselschrauber Bar
No new posts Find the brake PR code Transmission, Chassis, Body & Interior
