Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel?
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post28-03-2009, 15:30    Subject: Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel? Quote
"Because my clutch is quite soft and it stalls when I give it full throttle below 2000 RPM."
Can someone tell me which one fits my 5-speed gearbox?
The ZMS (torque dampener) for the AVF engine with a 6-speed transmission has a larger diameter and is more robust.
I would like to purchase one if it fits into my 5-speed gearbox.
I understand that a different starter motor is also needed.
Could a flywheel from a V6 TDI engine potentially be a good option, assuming it fits mechanically? icon_rolleyes.gif
B.Eng (FH) u. KFZ Meister
Translated on 25-09-2026, 21:09.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post30-03-2009, 20:22    Subject: Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel? Quote
Luke 4:15-12:10
Sachs 2294 000 453
or VAG 028 105 266 A or D, also AK.
These numbers are for the 228mm wheel that comes as original equipment. I can't help you with your modification plans.
Passat Variant BGW 2005
Translated on 25-09-2026, 21:10.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post13-04-2009, 9:47    Subject: Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel? Quote
Does anyone know if there's a difference between the two ZMS systems?
1- 03G 105 266 N
2- 03G 105 266 AT
The latter comes from a 2.0 170 hp -PD TDI A4 Quattro.
Translated on 25-09-2026, 21:11.
Steffen W
Post15-04-2009, 20:35    Subject: Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel? Quote
They are of the same design. The corresponding LUK part number for both OE numbers is, for example, 415 0244 10.
It also has the same design as the other two.
03G 105 266 BH
Translated on 25-09-2026, 21:12.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post15-04-2009, 22:28    Subject: Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel? Quote
03G 105 266 BH
Okay, thanks. I was almost sure. But it's still strange why they always assign different part numbers when the part is actually the same.
So, I now have 2 matching ZMS (presumably referring to a specific part) at home, which I will probably replace sometime this weekend. icon_biggrin.gif
Translated on 25-09-2026, 21:13.
Post16-04-2009, 7:15    Subject: Audi A4 8E: Best Dual Mass Flywheel (DMF) Quote
Steffarn wrote:
Since my ZMS is quite soft and hits the rev limiter at over 2000 RPM when under full throttle.
Hi Steffarn,
Which symptoms are you so sure are related to the dual-mass flywheel (DMF)? Or, why can you rule out other problems, such as a worn engine mount?
Translated on 25-09-2026, 21:14.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post16-04-2009, 17:31    Subject: Audi A4 8E: Best Dual Mass Flywheel (DMF) Quote
ulf wrote:
Steffarn wrote:
Because my clutch is quite soft and it slips at full throttle below 2000 RPM.
Hi Steffarn,
Which symptoms do you confidently attribute to the ZMS?
Or, why can you rule out other problems, such as a worn engine mount? }
Okay, the ZMS is still the first one. You can feel it when you're pushing it hard, as it jumps from 1500-2000 RPM and then hits the limiter.
"When doing chip tuning, the fuel injection amount had to be kept close to the standard level up to 2000 RPM. Otherwise, the engine would jerk violently under full load, making it undrivable. That's why I'm planning to install the larger ZMS (presumably a flywheel or similar component). Then everything will be fine."
Translated on 25-09-2026, 21:16.
Post16-04-2009, 17:46    Subject: Audi A4 8E: Best Dual Mass Flywheel (DMF) Quote
Steffarn wrote:
When you're pushing it to the limit, you can feel it as it hits the block between 1500 and 2000 RPM.
And what exactly does it feel like when it "hits the block"? That's what I meant by my question.icon_wink.gif
Translated on 25-09-2026, 21:17.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post16-04-2009, 20:55    Subject: Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel? Quote
It's difficult to compare. It feels similar to the jerky behavior sometimes seen in poorly tuned TDI engines, especially at lower speeds.
So, there's a vibration that occurs in sync with the engine's revolutions or combustion. Sometimes, it's so strong that the entire body of the car starts to resonate with the throbbing.
When driving with the windows open, you might also hear a creaking sound from the torsional springs in the dual-mass flywheel (DMF). This doesn't sound healthy.
Once you've diagnosed a few flywheel defects, you develop a sense for how to identify them.
I know of a case where the catalytic converter failed during an emissions test, causing the engine to seize and leaving the car in a really bad state.
I hope the used parts I got from the junkyard are in good condition.
The parts should only have 33,000 km on them. icon_sad.gif But I'm not sure I trust the seller when I see the clutch like this.
Translated on 25-09-2026, 21:18.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post16-04-2009, 21:02    Subject: Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel? Quote
Okay, the flywheel I'm going to install is from an AVF engine.
Part number: 038105266AC, which is no longer available and has been replaced by 03G105266N.
Translated on 25-09-2026, 21:20.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post21-04-2009, 17:21    Subject: Audi A4 8E 1.9 TDI AWX: Which Dual Mass Flywheel? Quote
Unfortunately, the renovation plans fell through.
The clutch disc from the 6-speed transmission does not fit into the transmission bell housing of the 5-speed transmission. icon_exclaim.gif
Therefore, the old version remains in place. icon_cry.gif It's a shame about the work.
[img]/download.php?id=3746[/img]
Translated on 25-09-2026, 21:21.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi C4 AAT/AEL: Which ECU when? Diesel Engine Technology
No new posts Engine Oil for 2.5 TDI: Best Choice & Guide Diesel Engine Technology
No new posts EDC17: Which programming tool? On-Board Diagnostics (OBD)
No new posts 1.8T engine with high mileage, what oil should I use? Gasoline Engine Technology
