What does "microencapsulated" mean?
Post24-04-2009, 8:40    Subject: What does "microencapsulated" mean? Quote
Hi.
The three rear screws of the engine mounting bracket on the 3C TDI are labeled "micro-encapsulated" and must be replaced after each removal.
What does "microencapsulated" mean, how does it work, and what happens if I don't replace it?
(With the Golf, I regularly removed the sound insulation panel, but I haven't dared to do that with the 3C yet.)
Translated on 06-07-2026, 9:59.
joegolf
dieselschrauber likes this.
Post24-04-2009, 9:07    Subject: What does "microencapsulated" mean? Quote
"Microencapsulated" means that a protective agent has been applied to the new foam. It melts when the screw is inserted, then hardens again, thus securing the screw.
If it is reused, the protective effect is naturally lost. In my opinion, when re-securing something, one could also apply a normal securing agent.
Some manufacturers also specify that certain coatings can be used multiple times. Details can be found on the relevant manufacturer websites (e.g., Loctite).
Golf 7 GTI
Translated on 06-07-2026, 10:00.
bloesch
Post24-04-2009, 14:56    Subject: What does "microencapsulated" mean? Quote
and what happens then, if I don't replace them.
nothing at all...
We haven't lost a single customer yet, and no one is creating anything new like it.
(I didn't even know they were supposed to be new icon_redface.gif).
Translated on 06-07-2026, 10:01.
pschaefer
Post24-04-2009, 22:14    Subject: Re: What does "microencapsulated" mean? Quote
dieselmartin wrote:
(With the Golf, I regularly removed the sound insulation panel, but I haven't dared to do that with the 3C yet).
"With my A3, I had to remove the sound insulation tray about 5 times. I never replaced those screws (they are incredibly tight even when new), and I also never applied any Loctite." And everything holds.
What's not so good are these other metal clips and screws (on the bumper cover and inner fender liner). First, they rust like the S*, and second, the clips easily come loose from their groove in the plastic, and then they can't be tightened properly anymore... icon_confused.gif
Translated on 06-07-2026, 10:02.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 08/01 MKB "AVF" GKB "EYF" Getrieb Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Austausch des RNS315 gegen neues "Discover Media" Electrical Systems, Vehicle Electronics, Multimedia
