Yesterday, while replacing the AGR (air intake control valve) and some seals, I noticed that my left engine mount has a dent in it. Besides the dent visible in the photos, the bearing is bulging outwards.
Is this normal, or is something broken? I'm experiencing a slight jerking sensation when starting up, below 1500 RPM. However, there are no error codes stored, and the clutch and dual-mass flywheel have already been replaced.
Edit: The whistling sound was caused by a leak in the intercooler piping. It is now clean and leak-proof again.
| Description: |
| Question about engine mounts. Defective? |
| File size: |
81.95 KB |
| Viewed: |
3102 times |
A4 Avant 08/01 AWX 05/08-
